> first start, whats the process
doobie123
post Apr 1 2023, 10:21 AM
hi i'm working on my 75 914, 2.0, 5 spd.
had the drive train out to do a clutch and also engine top including pistons rings and cylinders.
getting ready to start it for the first time and was wondering if there is a process or check list that anyone has used. i guess it would seem obvious to some but, i'm pretty new to this and don't want to get it wrong.
i was curious to know if there is a way to check oil pressure before actually starting it.
any suggestions would be great.
thanks
ogdougy
post Apr 1 2023, 11:34 AM
If you want to check oil pressure quickly. You have to crank the motor.
Pull the spark plugs. If FI unplug the injectors so you dont dump fuel in there, if carbed just dont fill the bowls.
Crank and you should generate enough pressure.
- Lo-Fi Version Time is now: 5th July 2026 - 01:13 AM
