| doobie123 |
Apr 1 2023, 10:21 AM
Member ![]() ![]() Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi i'm working on my 75 914, 2.0, 5 spd.
had the drive train out to do a clutch and also engine top including pistons rings and cylinders. getting ready to start it for the first time and was wondering if there is a process or check list that anyone has used. i guess it would seem obvious to some but, i'm pretty new to this and don't want to get it wrong. i was curious to know if there is a way to check oil pressure before actually starting it. any suggestions would be great. thanks |
| emerygt350 |
Apr 1 2023, 02:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,666 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I have heard many people that know anything these days don't really go along with break in routines anymore. Since you don't have a new cam, no worries there. Check for pressure (did you muck with the pump? ) Then just drive it like a normal person (maybe not like a 914 driver) making sure everything is good. Do you have gauges? Cht gauge? Oil temp? Oil pressure (I assume so)? If it were me I would extra paranoid for the first few miles, checking plugs frequently etc., But after it looks good I would relax.
doobie123 first start Apr 1 2023, 10:21 AM
ogdougy If you want to check oil pressure quickly. You hav... Apr 1 2023, 11:34 AM
doobie123 hi guys, thanks for the replies.
i did change the ... Apr 2 2023, 03:50 PM
wonkipop
i did change the... Apr 2 2023, 05:14 PM
r_towle Pull coil wire
Crank for a bit to get oil pressure... Apr 2 2023, 04:11 PM
emerygt350 Yeah, with no oil pressure gauge you have to just ... Apr 2 2023, 05:11 PM
iankarr Yep. Crank without spark till u have pressure. Sin... Apr 2 2023, 07:00 PM
Jack Standz
had ... Apr 2 2023, 11:30 PM
doobie123 thanks for the help ya'll.
cranked it until th... Apr 11 2023, 12:13 PM
emerygt350 Are you getting 12v to the coil? Apr 12 2023, 04:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th July 2026 - 01:13 AM |
