| PDXBob |
Mar 4 2023, 07:14 PM
Member ![]() ![]() Group: Members Posts: 63 Joined: 16-May 20 From: Portland Oregon Member No.: 24,272 Region Association: Pacific Northwest
Hi All,
I just finished putting on rebuilt rear brake calipers done by PMB. Also, new braided steel brake lines and set of new Textar pads on all 4 wheels (1975 914). I took it out to do the “bedding” break-in process and I noticed it was pulling to the right. So, (after doing cool down slow driving)when I got home I checked temperature of rotors. Both back rotors were about 125 degrees. However front right was about 240 degrees. BUT front left was only about 85 degrees. To a novice like me seems like front left is not working. Any suggestions on diagnostic procedures or what to check out. Thanks PDXBob |
| brubou |
Apr 5 2023, 04:14 PM
Bruce Bouchard ![]() ![]() Group: Members Posts: 92 Joined: 29-February 16 From: West Bradford, PA Member No.: 19,716 Region Association: MidAtlantic Region
Correct, there is a one way valve mechanism in them, probably using a spring and either a ball or something to block reverse flow.
PDXBob Front Brake Issue Mar 4 2023, 07:14 PM
bkrantz I would jack up the front and have an assistant gr... Mar 4 2023, 09:20 PM
ndfrigi When you bled the left front, does it push brake f... Mar 4 2023, 09:22 PM
PDXBob Good suggestions about bleeding again and spinning... Mar 4 2023, 11:15 PM
Krieger Recheck the venting clearance again on your rear c... Mar 4 2023, 11:36 PM
PatMc Make sure you're bleeding from the uppermost b... Mar 6 2023, 07:50 AM
Eric_Shea Hey Bob,
Are the soft lines new? If not then I w... Mar 6 2023, 09:15 AM
PDXBob
Hey Bob,
Are the soft lines new? If not then I ... Mar 7 2023, 04:40 PM
Eric_Shea
[quote name='Eric_Shea' post='3062899' date='Mar ... Mar 8 2023, 01:33 PM
technicalninja Rear brakes are damn hard to get hot enough to ... Mar 8 2023, 12:34 AM
Cairo94507 @Eric_Shea - Holly molly- 10 year unconditional w... Mar 8 2023, 05:11 PM
Eric_Shea Thank you Amigo! Mar 8 2023, 06:57 PM
PDXBob So, after performing several of the tests listed a... Mar 22 2023, 03:28 PM
930cabman
So, after performing several of the tests listed ... Mar 23 2023, 05:53 AM
PDXBob So, an update:
Had my front calipers just rebuilt ... Apr 4 2023, 09:36 PM
rjames
So, an update:
Had my front calipers just rebuilt... Apr 5 2023, 05:00 AM
PDXBob
[quote name='PDXBob' post='3069725' date='Apr 4 2... Apr 5 2023, 02:08 PM
technicalninja The rear adjustment can be difficult to gauge.
Jus... Apr 4 2023, 09:49 PM
emerygt350
Ju... Apr 6 2023, 04:21 PM
Olympic 914 Just ran through this myself.
Adjusted rear brak... Apr 5 2023, 07:02 AM
Superhawk996 Raise the rear of the car to help move air through... Apr 5 2023, 07:31 AM
brubou I would start at the beginning of the system. Thro... Apr 5 2023, 10:03 AM
rhodyguy Long hose=speed bleeders in the top caliper bleede... Apr 5 2023, 02:27 PM
PDXBob
Long hose=speed bleeders in the top caliper bleed... Apr 5 2023, 04:01 PM
rjames When I had my brakes refurbished they came with re... Apr 5 2023, 04:23 PM
rhodyguy You will see the bubbles traveling thru the tube w... Apr 5 2023, 04:25 PM
76-914 I run the hose all the way to the reservoir. That ... Apr 5 2023, 05:51 PM
rhodyguy Return to reservoir….I’m going to get new long... Apr 5 2023, 05:57 PM
emerygt350 Interesting. How do you seal the line at the blee... Apr 5 2023, 06:31 PM
rhodyguy You get tubing that’s a snug fit. The fluid is n... Apr 5 2023, 08:11 PM
emerygt350 I figured if you are running it all the way back i... Apr 6 2023, 06:09 AM
rjames
I figured if you are running it all the way back ... Apr 6 2023, 12:51 PM
PDXBob I’m going to try the long hose bleeding method s... Apr 6 2023, 06:17 PM
emerygt350 I am not there yet. I have been bleeding crappy o... Apr 6 2023, 07:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th July 2026 - 04:48 PM |
