SVG223 |
Member ![]() ![]() Group: Members Posts: 115 Joined: 6-February 22 From: Benton Arkansas Member No.: 26,317 Region Association: None ![]() |
In the middle of rebuilding/bleeding the brakes and the parking brake warning light is flashing while doing test drives and won't shut off. After checking the parking brake switch I do a little research and read about the brake pressure warning switch on the master cylinder which has a reset button. I'm thinking about how often I might have to reset the thing before I'm done with the brakes. What about cutting the wire to the switch until I decide to rebuild/replace the master cylinder, then reattach it? I don't think I need a flashing light to tell me that I have low brake pressure, that should be obvious.
SVG223 |
I pulled off the wire and it stopped flashing, which was good enough for me.
Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 18th September 2025 - 07:02 PM |
