| Geezer914 |
Jul 26 2010, 10:31 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,288 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Removed the steering wheel and turn signal/wiper switch. How do I get the lock cylinder out tho replace the ignition switch. This is on a 1975 914. Thanks.
| DRPHIL914 |
Apr 14 2023, 07:49 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,926 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
There are after market replacements, but they will not accept a Porsche key. Your stuck with a vw key I purchased the Bilstein (hopefully it is correct for the 71): https://www.partsgeek.com/gbproducts/WC/17028-01043671.html right now, I would accept a Doritos engaging the starter.. (IMG:style_emoticons/default/smile.gif) @broomhandle reviving an older thread here- did your Bilistein brand starter switch work? i had a no start the other day , it had to push start, when i got home it restarted fine, but i don’t want to take any chances, need to replace the switch, i ordered 3 of them, Bilistein , Mahle, and standard. the first 2 are made in Germany not china so i’m hoping either will work and last fine, i did a china one a couple years ago that didn’t work for long at all, and this one was a used one i had laying around i had to put back in when the 6 month old china one fail. So just wondering if the new german ones are working fine for others? my car is. ‘75 2.0 |
Geezer914 Ignition switch replacement on a 1975 914? Jul 26 2010, 10:31 AM
Kirmizi You need to remove the upper column to access it, ... Jul 26 2010, 11:50 AM
Geezer914 Thanks for the help. Jul 26 2010, 02:32 PM
charliew From what I remember there is more to it than that... Jul 26 2010, 03:56 PM
pilothyer Just go here....pictures, instructions, all you co... Jul 26 2010, 06:35 PM
broomhandle Hello, old thread dig up. Is this the same process... Jul 25 2022, 01:57 PM
GregAmy Halfway down
http://www.914world.com/specs/rekey.... Jul 25 2022, 02:15 PM
broomhandle
Halfway down
http://www.914world.com/specs/rekey... Jul 25 2022, 04:36 PM
TheCabinetmaker You can remove the steering lock from the column a... Jul 25 2022, 05:02 PM
TheCabinetmaker There are after market replacements, but they will... Jul 25 2022, 05:04 PM
broomhandle
There are after market replacements, but they wil... Jul 26 2022, 09:52 AM
dr914@autoatlanta.com look in your "Tech Tips 700" there is th... Apr 14 2023, 08:33 AM
76-914
look in your "Tech Tips 700" there is t... Apr 17 2023, 06:31 PM
jim_hoyland I went to a left side switch that a member here so... Apr 14 2023, 08:34 AM
DRPHIL914 i bought 3 new ignition switches.
1- Bilistein, i... Apr 17 2023, 10:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 03:16 AM |
