jmargush |
Member ![]() ![]() Group: Members Posts: 484 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
I am trying to diagnose if my oil temp sender is working.
I took a reading on the 20k scale, at room temp and got 1.8 1.9 ohms Put a little heat on it with propane torch for a few seconds and the reading is .003 - .004 ohms Funny thing is the meter will jump around a lot particularly if I slide the lead up and down the length of the sensor tip. Do anyone know if this resistance seems like the sensor is working or not? My gauge wasn't reading anything so i started with this as I was doing an oil change. |
jmargush |
wiring from the sensor to the gauge reads as good.
Grounding green wire terminal on gauge makes needle peg tot he right. So I am thinking the sensor is bad, is my thinking correct? |
Lo-Fi Version | Time is now: 18th August 2025 - 11:49 PM |
