jmargush |
Member ![]() ![]() Group: Members Posts: 484 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
I am trying to diagnose if my oil temp sender is working.
I took a reading on the 20k scale, at room temp and got 1.8 1.9 ohms Put a little heat on it with propane torch for a few seconds and the reading is .003 - .004 ohms Funny thing is the meter will jump around a lot particularly if I slide the lead up and down the length of the sensor tip. Do anyone know if this resistance seems like the sensor is working or not? My gauge wasn't reading anything so i started with this as I was doing an oil change. |
jmargush |
trying to figure this out.
I checked 3 different sensors that I have and a see resistance drop on the sensors when I apply heat from a torch. So I assume the sensors are working. I took the wire going to the senor under the car and grounded it and the gauge pegs. So I assume the wiring to the gauge is good. I plugged a sensor into the wire and applied heat from a torch onto the sensor. after about a minute the gauge hasn't moved. What am I missing? |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,083 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
trying to figure this out. I checked 3 different sensors that I have and a see resistance drop on the sensors when I apply heat from a torch. So I assume the sensors are working. I took the wire going to the senor under the car and grounded it and the gauge pegs. So I assume the wiring to the gauge is good. I plugged a sensor into the wire and applied heat from a torch onto the sensor. after about a minute the gauge hasn't moved. What am I missing? Was the case if the sender grounded when you heated it? If not you will not see the gauge move. They measure resistance to ground. |
Lo-Fi Version | Time is now: 18th August 2025 - 09:58 PM |
