| VaccaRabite |
Mar 17 2023, 09:03 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,952 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
About 18ish months ago I bought into a new engine program Eric and PMB were starting up. If you have seen me in person I've probably talked your ear off about it. Sorry about that, I've been pretty excited.
Mine is No2 off their line, and its crated up in Utah waiting for the shipper to pick it up. So its really real time here in Dallastown, and I've started getting my 2056 ready to come out. The new engine! (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1679065407.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1679065409.2.jpg) I *think* (and could be wrong) that Eric also used my motor as the promotional model for Facebook and his Web storefront - though that could have been Risdal's engine which was right behind mine. Eric and Larry did a lot of testing on the #1 engine in Jim's car, got a lot of driving data at Red Rocks last fall, and then had to wait on components to come in that resulted from that real world testing. My engine was crated last week. I asked Eric to include some other things (including his new brake lines and new pads), paid the final invoice for parts and shipping and the engine will hopefully be in my garage next week! @Stratplayer @Eric_Shea |
| VaccaRabite |
Apr 13 2023, 09:59 AM
I really thought I'd be starting it last night.
But after a 10 hour work day, running kids around, making dinner, etc... I got out to the shop around 9 and worked till I started fumbling with things like nuts and bolts. IE - an hour later then I should have been working. But I got a good bit done before I realized I was basically asleep on my feet and went to bed. CHT is in place. I had kinda been dreading this one, but its done. Its always the kinda stupid jobs that give me pause. But once I did it, it only took a few minutes. Hooked up the last fuel connection. I'm not happy with how the fuel lines are set right now. Since the deadline I set for driving got deleted due to Amy's upcoming surgery, I may redo this. The engine side hard lines I have just don't work with the rubber hose routing and I want to remake them. So I think I will do that before I put gas back in the car again. More work. I hooked up the injector connectors. Not to bad but they were not labeled so I had to be careful. I also remade the 12pin connector harness. I reused my old harness, but cut back the old wires and remade them. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1681401572.1.jpg) I'm kinda proud of this one. With custom wiring documentation is everything. 10 years from now I know I won't remember what I did. Instead of drawing the diagram and sticking it in my manual, I labeled the wires themselves by printing labels on heat-shrink tube. I got the shroud back on and hooked up the throttle cable. There is one cheesehead screw that does not want to go back in as the standoff is slightly misaligned. I'll need to fix it tonight. My main battery cable also needed some work. This is when how tired I was really started to show. I was fumbling with the battery connector and dropped the hold down nut. I probably just stood there looking into the engine bay for about 15 minutes. I was standing, but I wasn't really there. I tried to work for a little longer but gave it up and can't even recall what more i tried to do. One last thing, that I realized pretty quick last night when I thought I was going to start the car - I don't have the hose I need to rig up the breather - and I can't find my breather can. I hope I still have mine - I may have given it away since I usually just close the vent lines. For this engine, PMB wants the breather vents run to a catch can during break in, so that's what I am going to do. So, probably no start this week since I'm camping tomorrow though Sunday. I'm going to try and put a bow on the electrical stuff tonight and (if I have the energy) change the fuel hardline I don't like so my hose route is better. Then the only things I have left to do is: breather vents and catch can, add gas, and check for leaks Start it up! Zach |
| Jamie |
Apr 19 2023, 05:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,237 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
I really thought I'd be starting it last night. But after a 10 hour work day, running kids around, making dinner, etc... I got out to the shop around 9 and worked till I started fumbling with things like nuts and bolts. IE - an hour later then I should have been working. But I got a good bit done before I realized I was basically asleep on my feet and went to bed. CHT is in place. I had kinda been dreading this one, but its done. Its always the kinda stupid jobs that give me pause. But once I did it, it only took a few minutes. Hooked up the last fuel connection. I'm not happy with how the fuel lines are set right now. Since the deadline I set for driving got deleted due to Amy's upcoming surgery, I may redo this. The engine side hard lines I have just don't work with the rubber hose routing and I want to remake them. So I think I will do that before I put gas back in the car again. More work. I hooked up the injector connectors. Not to bad but they were not labeled so I had to be careful. I also remade the 12pin connector harness. I reused my old harness, but cut back the old wires and remade them. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1681401572.1.jpg) I'm kinda proud of this one. With custom wiring documentation is everything. 10 years from now I know I won't remember what I did. Instead of drawing the diagram and sticking it in my manual, I labeled the wires themselves by printing labels on heat-shrink tube. I got the shroud back on and hooked up the throttle cable. There is one cheesehead screw that does not want to go back in as the standoff is slightly misaligned. I'll need to fix it tonight. My main battery cable also needed some work. This is when how tired I was really started to show. I was fumbling with the battery connector and dropped the hold down nut. I probably just stood there looking into the engine bay for about 15 minutes. I was standing, but I wasn't really there. I tried to work for a little longer but gave it up and can't even recall what more i tried to do. One last thing, that I realized pretty quick last night when I thought I was going to start the car - I don't have the hose I need to rig up the breather - and I can't find my breather can. I hope I still have mine - I may have given it away since I usually just close the vent lines. For this engine, PMB wants the breather vents run to a catch can during break in, so that's what I am going to do. So, probably no start this week since I'm camping tomorrow though Sunday. I'm going to try and put a bow on the electrical stuff tonight and (if I have the energy) change the fuel hardline I don't like so my hose route is better. Then the only things I have left to do is: breather vents and catch can, add gas, and check for leaks Start it up! Zach OK, need to know, how did you print on heat shrink tubes? (IMG:style_emoticons/default/confused24.gif) |
VaccaRabite New Engine Time! Mar 17 2023, 09:03 AM
Craigers17 :trophy: That's a thing of beauty! Any dy... Mar 17 2023, 09:28 AM
VaccaRabite
:trophy: That's a thing of beauty! Any d... Mar 17 2023, 09:44 AM
StratPlayer
:trophy: That's a thing of beauty! Any ... Mar 17 2023, 10:22 AM
VaccaRabite Last night I started working on unhooking all the ... Mar 17 2023, 09:29 AM
Cairo94507 Wow! Very exciting news. What are the build ... Mar 17 2023, 09:29 AM
VaccaRabite Aside from the engine swap, that other tasks to be... Mar 17 2023, 09:33 AM
930cabman :beer1: Looks great, keep us informed of the prog... Mar 17 2023, 09:42 AM
914werke What is that shroud made out of? Mar 17 2023, 10:26 AM
NARP74
Hopefully alumi... Mar 17 2023, 11:39 AM
Dion Congratulations Zach. Look forward to seeing this ... Mar 17 2023, 10:30 AM
Superhawk996 Sure looks nice! :popcorn:
You going to dyn... Mar 17 2023, 11:42 AM
Mueller Wow, work of art...enjoy! Mar 17 2023, 11:54 AM
nditiz1 Looks excellent Zack, waiting in anticipation for ... Mar 17 2023, 12:04 PM
jim_hoyland Looks great ! The PMB upgrade is a giant step ... Mar 17 2023, 12:35 PM
rhodyguy I think the stock tin is still used. Mar 17 2023, 01:33 PM
NARP74
The cover a... Mar 17 2023, 02:12 PM
echocanyons This engine is pretty incredible, my son has the f... Mar 17 2023, 02:49 PM
VaccaRabite
This engine is pretty incredible, my son has the ... Mar 19 2023, 06:33 PM
echocanyons
This engine is pretty incredible, my son has the... Mar 24 2023, 11:17 PM
Craigers17 RE: New Engine Time! Mar 17 2023, 03:36 PM
burton73 Very excited for you guys to get these engines in ... Mar 17 2023, 04:35 PM
mlindner What a great new service to the 914 community. Tha... Mar 18 2023, 08:56 AM
OrangeBones Congrats - Can’t wait to see it at Carlisle. Mar 18 2023, 09:19 AM
VaccaRabite Bit of a hiccup as I spent 12 hours Friday helping... Mar 19 2023, 06:27 PM
mate914
Bit of a hiccup as I spent 12 hours Friday helpin... Mar 19 2023, 07:10 PM
infraredcalvin Sorry to hear about your friend, cancer sucks... Mar 19 2023, 07:52 PM
jaredmcginness Looks beautiful! Mar 20 2023, 05:44 AM
VaccaRabite The old engine is out.
I have to say I'm not ... Mar 23 2023, 07:54 AM
Cairo94507 That's amazing; 2.5 years of riding along in t... Mar 23 2023, 08:01 AM
Geezer914 Don't forget the ground strap connected to the... Mar 23 2023, 08:27 AM
NARP74 I call that hole the Abyss. I have lost many piec... Mar 23 2023, 08:34 AM
VaccaRabite
I call that hole the Abyss. I have lost many pie... Mar 23 2023, 11:23 AM
JmuRiz I guess that's why the VW version had a cage o... Mar 23 2023, 12:14 PM
I guess that's why the VW version had a cage ... Mar 23 2023, 12:36 PM
ClayPerrine
I guess that's why the VW version had a cage... Mar 23 2023, 12:41 PM
930cabman Engine had to be running out of balance for the en... Mar 23 2023, 12:53 PM
NARP74
Engine had to be running out of balance for the e... Mar 23 2023, 01:11 PM
VaccaRabite
Engine had to be running out of balance for the ... Mar 23 2023, 06:46 PM
SirAndy You can get them all day on ebay for $30. I... Mar 23 2023, 07:12 PM
euro911
You can get them all day on ebay for $30. I... Mar 25 2023, 03:25 PM
VaccaRabite Engine and transmission are now split. Alternator... Mar 23 2023, 06:56 PM
Root_Werks Very excited for your new engine!
The oil cap... Mar 24 2023, 10:43 AM
bzettner Whatcha going to do with your “old” engine? :... Mar 24 2023, 11:22 AM
930cabman
Whatcha going to do with your “old” engine? ... Mar 24 2023, 11:44 AM
GBX0073 I know Don on FB inquired and thought it should st... Mar 24 2023, 06:20 PM
GBX0073
I know Don on FB inquired and thought it should s... Mar 24 2023, 06:21 PM
hot_shoe914
I know Don on FB inquired and thought it should s... Mar 24 2023, 07:19 PM
hot_shoe914
I know Don on FB inquired and thought it should ... Mar 24 2023, 07:20 PM
JmuRiz Nice! Aaron’s gonna run a front cooler too. Mar 25 2023, 08:27 AM
r_towle is it running yet? Mar 25 2023, 12:42 PM
VaccaRabite I got a delivery today!
http://www.914world.co... Mar 29 2023, 01:37 PM
mepstein Don’t rush. Take your time and enjoy the process... Mar 29 2023, 01:57 PM
rfinegan WOW..that sure looks NICE
Congratulations on you n... Mar 29 2023, 02:09 PM
rjames That's a good looking crate right there!
... Mar 29 2023, 02:28 PM
Mayne Awesome! Is that a 911 (or 914-6) style oil co... Mar 29 2023, 03:17 PM
Mayne
Awesome! Is that a 911 (or 914-6) style oil c... Mar 29 2023, 03:18 PM
Dion Yea Zach! 6 oil tank. Hmmmm…. Mar 29 2023, 04:06 PM
VaccaRabite
Behind this... Mar 29 2023, 04:45 PM
aharder
Don’t rush. Take your time and enjoy the proces... Mar 29 2023, 06:20 PM
DRPHIL914
Don’t rush. Take your time and enjoy the proces... Mar 30 2023, 06:19 AM
VaccaRabite
Zach, congrats this looks so awesome!! i ... Mar 30 2023, 12:47 PM
rhodyguy Are ‘Nickies’ part of this build? Who’s head... Mar 30 2023, 10:33 AM
VaccaRabite Lots of work this weekend.
Saturday:
Major tasks:... Apr 2 2023, 08:38 PM
VaccaRabite Today was a shorter day. Took the GF out to brunc... Apr 2 2023, 08:59 PM
VaccaRabite Picked up the CV gaskets at Translog at lunch. Ho... Apr 3 2023, 01:09 PM
skota23 Oh cool,
I had seen a few pictures of this engin... Apr 3 2023, 02:23 PM
Cairo94507 That is coming along quite nicely. :beer2: Apr 3 2023, 02:24 PM
VaccaRabite Ticked a few more lines off the checklist.
Axles ... Apr 4 2023, 09:08 PM
Jamie
Axles... Apr 12 2023, 07:48 AM
930cabman Teach 'em when they are young. That's the ... Apr 5 2023, 02:03 PM
Root_Werks Great progress! Can't wait to hear about ... Apr 5 2023, 02:33 PM
VaccaRabite My GF just had surgery so progress has been a litt... Apr 7 2023, 09:30 AM
ClayPerrine
And then disaster!
I needed to add a wire to... Apr 7 2023, 11:21 AM
Root_Werks Good progress!
As for the wiring #@%!... Apr 7 2023, 10:36 AM
nditiz1 I also have one on hand if needed. Apr 7 2023, 11:47 AM
VaccaRabite Progress slowed a little so I could go camping wit... Apr 11 2023, 09:03 PM
JmuRiz If anyone needs this for their 914, it's you ... Apr 12 2023, 07:25 AM
VaccaRabite
If anyone needs this for their 914, it's you ... Apr 12 2023, 10:57 AM
r_towle teasing...and I should talk...but this feels like ... Apr 12 2023, 11:15 AM
VaccaRabite
teasing...and I should talk...but this feels like... Apr 12 2023, 11:24 AM
VaccaRabite No work tonight. It’s my eldest’s 15th birthda... Apr 13 2023, 07:22 PM
sixnotfour oldest son 15... Now I am Old... Happy Birthday.. Apr 13 2023, 07:32 PM
VaccaRabite Finally a little time to work today over lunch.
Fu... Apr 19 2023, 12:58 PM
Cairo94507 :popcorn: :beer2: Apr 19 2023, 02:22 PM
Root_Werks Getting closer! Apr 19 2023, 02:47 PM
nditiz1 Video or it didn't happen Apr 19 2023, 04:36 PM
VaccaRabite @jamie
Any modern label maker can load cassettes ... Apr 19 2023, 05:35 PM
VaccaRabite So close but no cigar tonight. :headbang:
http:... Apr 19 2023, 08:28 PM
VaccaRabite Thinking about this with a clearer head this morni... Apr 20 2023, 06:04 AM
DRPHIL914 :popcorn:
sorry to hear that- i somehow mislable... Apr 20 2023, 07:21 AM
VaccaRabite whtCGQ4mIVU
First start!
I let the 15 year o... Apr 20 2023, 07:44 PM
rhodyguy A facet fuel pump is perfect for getting gas out o... Apr 20 2023, 08:07 PM
nditiz1 Huzzah! :beer2: Apr 20 2023, 08:21 PM
GBX0073 Awesome !!!!!! Apr 20 2023, 10:42 PM
VaccaRabite Ordered a new Holley fuel pressure regulator, more... Apr 21 2023, 04:36 AM
BeatNavy Congrats, Zach! Lots of nice weather ahead so... Apr 21 2023, 04:58 AM
Cairo94507 That started nice and easy. Congratulations to yo... Apr 21 2023, 07:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 09:02 AM |
