2056 Ljet, MPG? |
2056 Ljet, MPG? |
Geezer914 |
Apr 14 2023, 03:11 PM
Geezer914 Group: Members Posts: 1,441 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Running a 2056 with Ljet, 9550 cam, 50mm TB, and 9:1 CR. Getting just over 15 mpg. Plugs look good, slight tan. Thoughts?
Geezer914 |
Apr 14 2023, 05:51 PM
I'll hook up the O2 meter and see where I am at. I know 14.2 is optimum, but is 13.7 better for performance?
brant |
Apr 15 2023, 08:39 AM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I'll hook up the O2 meter and see where I am at. I know 14.2 is optimum, but is 13.7 better for performance? Those numbers are not good for an air cooled motor Stoich is 14.7:1 And you will cook your motor quickly with that ratio Do some research At redline you want around 12.5:1 AFR I routinely get 32 mpg in my 2.0/djet |
worn |
Apr 21 2023, 06:19 PM
can't remember Group: Members Posts: 3,162 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I'll hook up the O2 meter and see where I am at. I know 14.2 is optimum, but is 13.7 better for performance? Those numbers are not good for an air cooled motor Stoich is 14.7:1 And you will cook your motor quickly with that ratio Do some research At redline you want around 12.5:1 AFR I routinely get 32 mpg in my 2.0/djet It is all taken apart at present, but I found the motor gave more power as I approached stoichiometry, but wanted to burn to an inedible crisp. Hate to waste fuel, but there are limits. I got 25 to 30 mpg with a 2056, but that varied with my willingness to gamble. |
Lo-Fi Version | Time is now: 6th June 2024 - 10:15 PM |
