| 913B |
Apr 22 2023, 12:39 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
I am going Microsquirt. My current muffler right before I tried cleaning the dust off the part label and it just incinerated is a Dansk 1.8 muffler from what the PO said.
I did have to reweld and rotate tip to exit correctly under the valence. Maybe it was a bus muffler? Anyone have any experience on where to place the AF sensor bung, too bad its not on the car to check for clearance/obstruction issues. I was thinking of welding it on the tail pipe where the black circle I marked off. I could buy a new exhaust with the bung attached, but this is my attempt at going Microsquirt without spending too much and work with what I have. Anyone cut one up before and know of a good spot? Thanks in advance. Ted |
emerygt350 You are going to want it closer to the heat I thin... Apr 22 2023, 05:35 AM
BeatNavy I've been running Microsquirt for a couple of ... Apr 22 2023, 05:35 AM
StarBear This bung may be my next project - maybe this comi... Apr 22 2023, 06:19 AM
76-914 Within 12" of the header. If installing on a ... Apr 22 2023, 08:24 AM
StarBear
Within 12" of the header. If installing on a... Apr 22 2023, 09:36 AM
technicalninja WB O2 sensors are heated and can be placed anywher... Apr 22 2023, 10:10 AM
Superhawk996
One work around might be to lengthen the tip. I d... Apr 22 2023, 11:37 AM
technicalninja Superhawk, your car would look great in leopard pr... Apr 23 2023, 10:32 AM
Superhawk996
Still BIG and expensive!
Child’s play.
... Apr 23 2023, 10:44 AM
914werke You'll be money ahead replacing that with an d... Apr 23 2023, 02:28 PM
913B Dang a Horiba $2999, new Bursch exahaust ... Apr 23 2023, 04:14 PM
technicalninja And remember that Horiba is USED!
Parts for it... Apr 23 2023, 04:52 PM
914werke Dang a new Bursch exahaust $899!! t... Apr 24 2023, 09:58 AM
pilothyer
Dang a new Bursch exahaust $899!! ... Sep 12 2023, 04:28 AM
technicalninja I'd put it in the final collector where the tw... Sep 12 2023, 06:16 AM
burton73
I'd put it in the final collector where the t... Sep 12 2023, 06:43 AM
technicalninja That location is EXCELLENT!
You are going to ... Sep 12 2023, 06:57 AM
VaccaRabite When I had the Triad exhaust on my car adding the ... Sep 12 2023, 08:42 AM
JamesM Best location with your current muffler would prob... Sep 12 2023, 10:57 AM
913B I got a new to me muffler.
I believe it was origi... Oct 13 2023, 07:41 PM
technicalninja I would need to figure out where all primaries cam... Oct 13 2023, 10:01 PM
mb911 I have absolutely ZERO to do with 914 rubber. That... Oct 14 2023, 04:23 AM
913B Reviving my old thread, any member have a clue wh... Jun 14 2026, 09:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 04:56 AM |
