> Best Location for AF Sensor Bung, UPDATE: I got a SS muffler, what you all say now...
913B
post Apr 22 2023, 12:39 AM
I am going Microsquirt. My current muffler right before I tried cleaning the dust off the part label and it just incinerated is a Dansk 1.8 muffler from what the PO said.
I did have to reweld and rotate tip to exit correctly under the valence.
Maybe it was a bus muffler?
Anyone have any experience on where to place the AF sensor bung, too bad its not on the car to check for clearance/obstruction issues.
I was thinking of welding it on the tail pipe where the black circle I marked off.
I could buy a new exhaust with the bung attached, but this is my attempt at going Microsquirt without spending too much and work with what I have.
Anyone cut one up before and know of a good spot?
Thanks in advance.
Ted
BeatNavy
post Apr 22 2023, 05:35 AM
I've been running Microsquirt for a couple of years now. I don't have experience with that specific muffler, but if I had to guess the place you propose is as good as any. I'm always hesitant to drill into the "body" of the muffler for fear of upsetting the internals, and you don't have too many options there. I'm sure others can provide more specific guidance.
Yes, clearance is an issue to be concerned about. Take into account not just the sensor but the cable and the fact that you have to get it all lined up to thread it into the bung. That means you either need more space than you may realize or you have to remove the muffler before installing/removing the sensor.
Running Microsquirt in closed-loop on a type IV can be a little tricky, particularly at idle. Idle AFR numbers can be misleading on our motors due to a number of factors. I initially ran closed-loop using a stainless steel, dual-tip muffler sold by a vendor here. It had the O2 sensor bung pre-installed, presumably in the "best" location. It is a great muffler, but for whatever reason I could NOT get usable AFR numbers at idle. Always showed way too lean and had me chasing my tail for months. Above 1500 RPM or so it was fine and closed loop worked great, but idle was useless.
Eventually I switched to another vendor's muffler, with single-tip, and voila', my AFR numbers at idle were useful.
So: make sure you heat exchangers/headers aren't leaking at the heads. Make sure your muffler is not leaking at the heat exchangers. And don't drive yourself crazy chasing a specific idle AFR or closed loop setup at idle if it just won't happen with this muffler.
913B   Best Location for AF Sensor Bung   Apr 22 2023, 12:39 AM
emerygt350   You are going to want it closer to the heat I thin...   Apr 22 2023, 05:35 AM
BeatNavy   I've been running Microsquirt for a couple of ...   Apr 22 2023, 05:35 AM
StarBear   This bung may be my next project - maybe this comi...   Apr 22 2023, 06:19 AM
76-914   Within 12" of the header. If installing on a ...   Apr 22 2023, 08:24 AM
StarBear   Within 12" of the header. If installing on a...   Apr 22 2023, 09:36 AM
technicalninja   WB O2 sensors are heated and can be placed anywher...   Apr 22 2023, 10:10 AM
Superhawk996   One work around might be to lengthen the tip. I d...   Apr 22 2023, 11:37 AM
technicalninja   Superhawk, your car would look great in leopard pr...   Apr 23 2023, 10:32 AM
Superhawk996   Still BIG and expensive! Child’s play. ...   Apr 23 2023, 10:44 AM
914werke   You'll be money ahead replacing that with an d...   Apr 23 2023, 02:28 PM
913B   Dang a Horiba $2999, new Bursch exahaust ...   Apr 23 2023, 04:14 PM
technicalninja   And remember that Horiba is USED! Parts for it...   Apr 23 2023, 04:52 PM
914werke   Dang a new Bursch exahaust $899!! t...   Apr 24 2023, 09:58 AM
pilothyer   Dang a new Bursch exahaust $899!! ...   Sep 12 2023, 04:28 AM
technicalninja   I'd put it in the final collector where the tw...   Sep 12 2023, 06:16 AM
burton73   I'd put it in the final collector where the t...   Sep 12 2023, 06:43 AM
technicalninja   That location is EXCELLENT! You are going to ...   Sep 12 2023, 06:57 AM
VaccaRabite   When I had the Triad exhaust on my car adding the ...   Sep 12 2023, 08:42 AM
JamesM   Best location with your current muffler would prob...   Sep 12 2023, 10:57 AM
913B   I got a new to me muffler. I believe it was origi...   Oct 13 2023, 07:41 PM
technicalninja   I would need to figure out where all primaries cam...   Oct 13 2023, 10:01 PM
mb911   I have absolutely ZERO to do with 914 rubber. That...   Oct 14 2023, 04:23 AM
913B   Reviving my old thread, any member have a clue wh...   Jun 14 2026, 09:52 PM
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: friethmiller
- Lo-Fi Version Time is now: 15th June 2026 - 04:55 AM
