> Best Location for AF Sensor Bung, UPDATE: I got a SS muffler, what you all say now...
913B
post Apr 22 2023, 12:39 AM
I am going Microsquirt. My current muffler right before I tried cleaning the dust off the part label and it just incinerated is a Dansk 1.8 muffler from what the PO said.
I did have to reweld and rotate tip to exit correctly under the valence.
Maybe it was a bus muffler?
Anyone have any experience on where to place the AF sensor bung, too bad its not on the car to check for clearance/obstruction issues.
I was thinking of welding it on the tail pipe where the black circle I marked off.
I could buy a new exhaust with the bung attached, but this is my attempt at going Microsquirt without spending too much and work with what I have.
Anyone cut one up before and know of a good spot?
Thanks in advance.
Ted
technicalninja
post Apr 22 2023, 10:10 AM
WB O2 sensors are heated and can be placed anywhere in the system.
On a turboed car we put them at least 18" down the exhaust system as the heat can shorten their life.
Any sensor in the exhaust system should be "in the roof" as water is a significant byproduct of an ICE engine.
1 gallon of fuel burned equals approximately 1 gallon of water output. Some sources say more!
The only place that both sides come together is internally in the muffler and at that tip.
The tip looks fine with one exception...
Any negative pulses (shitloads in an exhaust system) will pull clean air UP that tip and it will probably read leaner that it actually is...
Does someone have a cut-away picture of the inside of a log type muffler?
Where the two sides come together internally in the muffler is where I'd want my sensor. Placing the sensor in a primary will only show that cylinders AFR. Placing at tip may yield in-accurate results.
Really serious folks will put one in each primary with individual EGT probes as well.
Car ends up looking like a science experiment...
One work around might be to lengthen the tip. I don't know how long it needs to be but I would think something 24" long would tend to reduce the fresh air pull that can happen.
The short tube effect on the sensor would be more prevalent at low engine speeds IMO.
913B   Best Location for AF Sensor Bung   Apr 22 2023, 12:39 AM
emerygt350   You are going to want it closer to the heat I thin...   Apr 22 2023, 05:35 AM
BeatNavy   I've been running Microsquirt for a couple of ...   Apr 22 2023, 05:35 AM
StarBear   This bung may be my next project - maybe this comi...   Apr 22 2023, 06:19 AM
76-914   Within 12" of the header. If installing on a ...   Apr 22 2023, 08:24 AM
StarBear   Within 12" of the header. If installing on a...   Apr 22 2023, 09:36 AM
technicalninja   WB O2 sensors are heated and can be placed anywher...   Apr 22 2023, 10:10 AM
Superhawk996   One work around might be to lengthen the tip. I d...   Apr 22 2023, 11:37 AM
technicalninja   Superhawk, your car would look great in leopard pr...   Apr 23 2023, 10:32 AM
Superhawk996   Still BIG and expensive! Child’s play. ...   Apr 23 2023, 10:44 AM
914werke   You'll be money ahead replacing that with an d...   Apr 23 2023, 02:28 PM
913B   Dang a Horiba $2999, new Bursch exahaust ...   Apr 23 2023, 04:14 PM
technicalninja   And remember that Horiba is USED! Parts for it...   Apr 23 2023, 04:52 PM
914werke   Dang a new Bursch exahaust $899!! t...   Apr 24 2023, 09:58 AM
pilothyer   Dang a new Bursch exahaust $899!! ...   Sep 12 2023, 04:28 AM
technicalninja   I'd put it in the final collector where the tw...   Sep 12 2023, 06:16 AM
burton73   I'd put it in the final collector where the t...   Sep 12 2023, 06:43 AM
technicalninja   That location is EXCELLENT! You are going to ...   Sep 12 2023, 06:57 AM
VaccaRabite   When I had the Triad exhaust on my car adding the ...   Sep 12 2023, 08:42 AM
JamesM   Best location with your current muffler would prob...   Sep 12 2023, 10:57 AM
913B   I got a new to me muffler. I believe it was origi...   Oct 13 2023, 07:41 PM
technicalninja   I would need to figure out where all primaries cam...   Oct 13 2023, 10:01 PM
mb911   I have absolutely ZERO to do with 914 rubber. That...   Oct 14 2023, 04:23 AM
913B   Reviving my old thread, any member have a clue wh...   Jun 14 2026, 09:52 PM
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: friethmiller
- Lo-Fi Version Time is now: 15th June 2026 - 04:54 AM
