| 913B |
Apr 22 2023, 12:39 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
I am going Microsquirt. My current muffler right before I tried cleaning the dust off the part label and it just incinerated is a Dansk 1.8 muffler from what the PO said.
I did have to reweld and rotate tip to exit correctly under the valence. Maybe it was a bus muffler? Anyone have any experience on where to place the AF sensor bung, too bad its not on the car to check for clearance/obstruction issues. I was thinking of welding it on the tail pipe where the black circle I marked off. I could buy a new exhaust with the bung attached, but this is my attempt at going Microsquirt without spending too much and work with what I have. Anyone cut one up before and know of a good spot? Thanks in advance. Ted |
| technicalninja |
Apr 23 2023, 04:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
And remember that Horiba is USED!
Parts for it may be "Hens Teeth"! I've got what I believe is a Bursch copy that extends the primaries into a 4-way flange and has a single tube into a simple muffler. That tube is where I'm putting my sensor. So, a good answer from me on where to place the O2 sensor bung is after the primaries have come together, before the muffler section, as far away from the heat as possible, and mounted in the roof of the pipe. If I had 3K to spend on my 914s exhaust I'd just hit up Chris Foley as his systems look perfect to me, opposing cylinders are paired, clean collectors, and his O2 sensor bungs are in the right place. Nice stuff in my book. That's where I'd put 3K... |
913B Best Location for AF Sensor Bung Apr 22 2023, 12:39 AM
emerygt350 You are going to want it closer to the heat I thin... Apr 22 2023, 05:35 AM
BeatNavy I've been running Microsquirt for a couple of ... Apr 22 2023, 05:35 AM
StarBear This bung may be my next project - maybe this comi... Apr 22 2023, 06:19 AM
76-914 Within 12" of the header. If installing on a ... Apr 22 2023, 08:24 AM
StarBear
Within 12" of the header. If installing on a... Apr 22 2023, 09:36 AM
technicalninja WB O2 sensors are heated and can be placed anywher... Apr 22 2023, 10:10 AM
Superhawk996
One work around might be to lengthen the tip. I d... Apr 22 2023, 11:37 AM
technicalninja Superhawk, your car would look great in leopard pr... Apr 23 2023, 10:32 AM
Superhawk996
Still BIG and expensive!
Child’s play.
... Apr 23 2023, 10:44 AM
914werke You'll be money ahead replacing that with an d... Apr 23 2023, 02:28 PM
913B Dang a Horiba $2999, new Bursch exahaust ... Apr 23 2023, 04:14 PM
914werke Dang a new Bursch exahaust $899!! t... Apr 24 2023, 09:58 AM
pilothyer
Dang a new Bursch exahaust $899!! ... Sep 12 2023, 04:28 AM
technicalninja I'd put it in the final collector where the tw... Sep 12 2023, 06:16 AM
burton73
I'd put it in the final collector where the t... Sep 12 2023, 06:43 AM
technicalninja That location is EXCELLENT!
You are going to ... Sep 12 2023, 06:57 AM
VaccaRabite When I had the Triad exhaust on my car adding the ... Sep 12 2023, 08:42 AM
JamesM Best location with your current muffler would prob... Sep 12 2023, 10:57 AM
913B I got a new to me muffler.
I believe it was origi... Oct 13 2023, 07:41 PM
technicalninja I would need to figure out where all primaries cam... Oct 13 2023, 10:01 PM
mb911 I have absolutely ZERO to do with 914 rubber. That... Oct 14 2023, 04:23 AM
913B Reviving my old thread, any member have a clue wh... Jun 14 2026, 09:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 04:55 AM |
