sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 955 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Restoring a matching numbers six.Wondering what upgrades
are acceptable… Such as oil fed tensioners and engine head studs all for reliability.j What’s the general feeling since these are not s”period correct”. Thanks |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Steel head studs are perfectly fine (and sometimes preferred) for a stock or modified motor. Some of the aftermarket head studs are only for aluminum cases since they use much higher torque specs.
Porsche didn’t always get it right the first time around and changes like tensioners are a worthwhile upgrade. You won’t go to Porsche hell if you use them on a stock engine. |
sixaddict |
Mark
Curious…..does that mean I still need to replace head studs but using stock/OEM Not positive and want to br sure especially with your experience. Thanks Steel head studs are perfectly fine (and sometimes preferred) for a stock or modified motor. Some of the aftermarket head studs are only for aluminum cases since they use much higher torque specs. Porsche didn’t always get it right the first time around and changes like tensioners are a worthwhile upgrade. You won’t go to Porsche hell if you use them on a stock engine. |
Lo-Fi Version | Time is now: 14th July 2025 - 07:59 PM |
