Super penetrating oil |
sixaddict |
May 1 2023, 05:31 PM
Senior Member Group: Members Posts: 805 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
sixaddict |
May 3 2023, 05:27 PM
Help.
Two STUCK studs. Used heat, special Collette tool, impact wrench and tapping. 3 days still no luck. Ideas?.. |
blabla914 |
May 3 2023, 05:44 PM
I like primer Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None |
Help. Two STUCK studs. Used heat, special Collette tool, impact wrench and tapping. 3 days still no luck. Ideas?.. What are the studs in? If they are head studs I've always found it hard to put enough heat on a head stud. I mean the head is designed to dissipate heat right? I've only had luck with acetylene or welding a nut right onto the stud. If you are using a MIG setup for sheet metal with like 0.023 wire you need to really crank it up. Do it along with copious amounts of penetrating oil. Have plenty of ventilation and be prepared for some fires. Plan on a mess. Good Luck Kelly |
Lo-Fi Version | Time is now: 6th June 2024 - 11:10 PM |
