> Brakes Pull to the Right
bkrantz
post May 3 2023, 08:25 PM
Some of you might remember my struggle to get what I considered strong braking, even after many rounds of bleeding, bedding, pad brand changes, and voodoo. I finally noticed how much the firewall flexed and the master cylinder moved under hard pedal pressure, and built a brace to support it. See my main thread.
On my first drive of 2023, the brakes finally felt strong, and I could lock up the front pretty easily. But with strong brake response I now have strong pull to the right.
I did set the rear pad clearance on both sides, inside and out, to .004".
Any suggestions?
One thing I have not done yet is corner weight balance. If the right front (and left rear) are carrying too much weight, would that make the car pull to the right as the weight shifts forward under hard braking?
Front yard mechanic
post May 5 2023, 09:53 AM
Only hit the brakes when your turning right
Superhawk996
post May 5 2023, 10:44 AM
QUOTE(Front yard mechanic @ May 5 2023, 10:53 AM) *
(IMG:style_emoticons/default/lol-2.gif) good point - driving a 914 is all about maintaining momentum and keeping cornering speeds up.
Now . . . About those left turns (IMG:style_emoticons/default/biggrin.gif)
- Lo-Fi Version Time is now: 12th July 2025 - 03:05 PM
