2056 mild carb settings, new tune advice needed |
RFoulds |
May 8 2023, 05:58 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
Now that the milder 2056 is in the car, I could use some advice on carb tune.
compression is at 8.8:1, valves are 44/38, cam is Webcam 86a. Weber IDF 40's have 37mm venturis, 135 mains airjets 200 F11 emulsion tube I am told by the builder that I should step down to 34 venturis, but, have no idea where else to start. Car will go to a good tuner soon enough, just want o have a good starting point. |
r_towle |
May 8 2023, 07:18 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Agree with above
Venturis are fir airflow volume and speed Smaller venturis offer faster yet less air at low rpm 28mm is right for Street application I think it has always been up by 2mm each time. I have a box of multiples of each part….each motor is different, and your elevation also matters. 28mm vents Tune idle jets, f-tube, and main jets to your needs. |
Lo-Fi Version | Time is now: 4th June 2024 - 09:35 AM |
