Dual 40 IDF'S really weird . . . ., defective Spanish casting???? |
ghettojet |
May 14 2023, 08:44 PM
Newbie Group: Members Posts: 6 Joined: 20-March 22 From: queens new york Member No.: 26,409 Region Association: North East States |
1.8 engine rebuilt by me.New Weber IDF's from CB Performance.
Engine is being bench run Fuel pressure 3.0lb,even tried a little less at one point. Good strong spark all around Timing is on. No gas in idle circuit cylinders #1 & 4 Mixture screws on this carb have no effect took apart carb,blew air through idle jet passages double checked float height. all good. Compression good engine has a few hours on it Finally I swapped carbs Problem follows the carb Now #2 & 3 not "participating" air correction 2.00 emulsion tubeF-11 Main 1.15 Idle .50 Venturi 28mm Only thing I can think here is that the actual casting is defective internally? Seems far fetched Am I missing something? not sure what I can do except return carb to CB Performance Would rather not do this Please advise |
Front yard mechanic |
May 15 2023, 05:48 AM
Senior Member Group: Members Posts: 1,171 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Take them apart again and make sure to check float levels. Remove all and reassemble them I’ll bet it is clogged somewhere. The lube they use when they assemble them new dries up and turns gummy bear.
Lo-Fi Version | Time is now: 6th June 2024 - 12:37 PM |
