| Tdskip |
May 25 2023, 07:21 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,784 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Good morning.
I managed to track down a couple pair of 3 inch caliper spacing Brembos. I started to do some initial fitment validation and realized that one pair fits perfectly on a vented front disk 3 inch caliper spacing whereas the other fits the same 3 inch caliper spacing perfectly but has too narrow of an opening where the disc goes so it’ll only work on unvented brake rotors. Any tips or coaching here on with the narrower pair will fit – is it simply a matter of needing an earlier non-vented from brake set up? In other words, one pair works fine with a 911 SC brake set up and I’m assuming the other pair should be fine with a non-vented 914 rotor? Thanks. |
| Tdskip |
May 25 2023, 10:31 AM
Thanks for the response. They actually have removed all the references to these calipers from their site, or at least anything that ties them back to being from an Alfa anyway.
Tdskip Yes, Brembo questions. Again. May 25 2023, 07:21 AM
914Sixer Maybe Eric Shea will chime in. Spacers may have b... May 25 2023, 08:26 AM
mepstein I’m pretty sure they work with solid 5 lug rotor... May 25 2023, 10:35 AM
eeyore I have stock early 911 solid rotors on my 5 lug co... May 25 2023, 10:35 AM
jim_hoyland Where do you the caliper spacers ? May 25 2023, 08:48 PM
Tdskip Thanks for the discussion.
I wasn’t as clear as... May 25 2023, 10:00 PM
PatMc
I wasn’t as clear a... May 26 2023, 07:22 AM
Tdskip
I wasn’t as clear ... May 26 2023, 08:17 AM
Krieger
I wasn’t as clear ... May 26 2023, 08:23 AM
I wasn’t as clear ... May 26 2023, 09:03 AM
Tdskip OK - took a while but am back with the program tha... May 27 2023, 05:55 AM
Tdskip Thanks for the discussion gentlemen.
Any tips on ... Jun 1 2023, 06:44 AM
Any tips on... Jun 1 2023, 08:31 AM
Krieger
Any tips o... Jun 1 2023, 09:48 AM
Krieger Maybe PMB has an extra set. They did buy a stash ... Jun 1 2023, 07:23 AM
Literati914 As a first step, contact the person you got the no... Jun 1 2023, 09:52 AM
As a first step, contact the person you got the n... Jun 1 2023, 11:13 AM
jcd914 I have 3 pair of the Alfa Brembo calipers and they... Jun 1 2023, 11:17 AM
Literati914
.. In other words, one pair works fine with a 911... Jun 1 2023, 11:22 AM
Eric_Shea We should have extra spacers and fasteners Jun 1 2023, 02:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th November 2026 - 07:21 PM |
