| chrispovoas |
May 25 2023, 04:21 PM
Member ![]() ![]() Group: Members Posts: 67 Joined: 8-April 23 From: New Zealand Member No.: 27,285 Region Association: Australia and New Zealand |
Morning fellow 914ers!
Well, i cant seem to find ANY info online re this so hoping someone can help. I'm talking engine heater blower brackets and the correct one for a '73. I have the single hose outlet motor (which i believe is correct for a '73), but with the dual hose attachment so I can run hoses to both heat exchanger inlets (Passenger and Drivers sides). However, I cant find a single picture that shows the actual bracket and motor installed. Just lots of pictures of the installed motor, but with no shot of the bracket. I've added a few picks of various installations which look correct, and a picture of the bracket i "assume" is the right one? Thoughts guys? Cheers Chris Attached thumbnail(s) Attached image(s)
| wonkipop |
May 25 2023, 05:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,548 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
actually my dementia memory might be coming back,
i think you feed the pipe clamp through the curved bracket in body work, then you feed the motor into that and tighten the bolt. the bracket from memory (the bit hidden from sight is sheet metal). its like a flat section of curve. i think i can remember you feed the clamp through it (its like a hollow raised passage). not doing too well with words but if i took it all apart you would see instantly. but its quite a job to get all that apart down there in an L jet. hope that helps. (IMG:style_emoticons/default/beerchug.gif) |
chrispovoas Brackets, Brackets, Brackets! May 25 2023, 04:21 PM
BillJ Please post direct. Cannot access your one drive ... May 25 2023, 04:29 PM
chrispovoas
Please post direct. Cannot access your one drive... May 25 2023, 04:45 PM
wonkipop yeah
the PET could be mildly described as highly ... May 25 2023, 05:01 PM
chrispovoas
actually my dementia memory might be coming back... May 25 2023, 05:17 PM
wonkipop i think that black flat sheet metal bracket that y... May 25 2023, 05:07 PM
bbrock There is also a thin rubber pad that goes between ... May 26 2023, 12:58 AM
sportlicherFahrer The bracket posted in the first group of pictures ... May 26 2023, 09:02 AM
wonkipop
The bracket posted in the first group of pictures... May 26 2023, 04:10 PM
Olympic 914 Bracket '73
I had also added the dual hos... May 26 2023, 09:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 09:37 PM |
