> Yes, Brembo questions. Again.
Tdskip
post May 25 2023, 07:21 AM
Good morning.
I managed to track down a couple pair of 3 inch caliper spacing Brembos.
I started to do some initial fitment validation and realized that one pair fits perfectly on a vented front disk 3 inch caliper spacing whereas the other fits the same 3 inch caliper spacing perfectly but has too narrow of an opening where the disc goes so it’ll only work on unvented brake rotors.
Any tips or coaching here on with the narrower pair will fit – is it simply a matter of needing an earlier non-vented from brake set up? In other words, one pair works fine with a 911 SC brake set up and I’m assuming the other pair should be fine with a non-vented 914 rotor?
Thanks.
Tdskip
post May 25 2023, 10:00 PM
Thanks for the discussion.
I wasn’t as clear as I needed to be - the vented rotor is too wide for the opening on the caliper. Think the non-vented will be OK, will see if it clears a 914 rotor (as a proxy) and report back.
Thanks!
PatMc
post May 26 2023, 07:22 AM
QUOTE(Tdskip @ May 25 2023, 11:00 PM) *
Thanks!
Either you have 2 different calipers or 2 different thickness rotors. Brembo calipers have never used spacers (like Ate calipers do). Start measuring and see what's wrong
Tdskip
post May 26 2023, 08:17 AM
QUOTE(PatMc @ May 26 2023, 08:22 AM) *
Thanks!
Good morning - I do have two different pair, one pair that works fine with vented rotors and one pair where the caliper is too narrow for vented rotors.
Both have 3 inch bolt spacing.
Tdskip   Yes, Brembo questions. Again.   May 25 2023, 07:21 AM
914Sixer   Maybe Eric Shea will chime in. Spacers may have b...   May 25 2023, 08:26 AM
Tdskip   Thanks for the response. They actually have remove...   May 25 2023, 10:31 AM
mepstein   I’m pretty sure they work with solid 5 lug rotor...   May 25 2023, 10:35 AM
eeyore   I have stock early 911 solid rotors on my 5 lug co...   May 25 2023, 10:35 AM
jim_hoyland   Where do you the caliper spacers ?   May 25 2023, 08:48 PM
Tdskip   Thanks for the discussion. I wasn’t as clear as...   May 25 2023, 10:00 PM
PatMc   Thanks for the discussion. I wasn’t as clear a...   May 26 2023, 07:22 AM
Tdskip   Thanks for the discussion. I wasn’t as clear ...   May 26 2023, 08:17 AM
Krieger   Thanks for the discussion. I wasn’t as clear ...   May 26 2023, 08:23 AM
mepstein   Thanks for the discussion. I wasn’t as clear ...   May 26 2023, 09:03 AM
Tdskip   OK - took a while but am back with the program tha...   May 27 2023, 05:55 AM
Tdskip   Thanks for the discussion gentlemen. Any tips on ...   Jun 1 2023, 06:44 AM
mepstein   Thanks for the discussion gentlemen. Any tips on...   Jun 1 2023, 08:31 AM
Krieger   Thanks for the discussion gentlemen. Any tips o...   Jun 1 2023, 09:48 AM
Krieger   Maybe PMB has an extra set. They did buy a stash ...   Jun 1 2023, 07:23 AM
Literati914   As a first step, contact the person you got the no...   Jun 1 2023, 09:52 AM
mepstein   As a first step, contact the person you got the n...   Jun 1 2023, 11:13 AM
jcd914   I have 3 pair of the Alfa Brembo calipers and they...   Jun 1 2023, 11:17 AM
Literati914   .. In other words, one pair works fine with a 911...   Jun 1 2023, 11:22 AM
Eric_Shea   We should have extra spacers and fasteners   Jun 1 2023, 02:40 PM
- Lo-Fi Version Time is now: 27th November 2026 - 07:21 PM
