| Osnabruck914 |
May 24 2023, 11:47 AM
Member ![]() ![]() Group: Members Posts: 214 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
My wife snapped this pic in a roundabout as we were entering Friedrichshaven about two weeks ago. Apparently there was a car show in the area that day, as there were quite a lot of interesting cars on the road. This was the only 914 we saw on the road in three weeks in Germany. Anyone's here or know this car?
Osnabruck914 ![]() |
| dt4 |
May 25 2023, 11:20 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England
| KELTY360 |
May 25 2023, 03:38 PM
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,192 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest
| Osnabruck914 |
May 25 2023, 05:28 PM
[/quote]
That front fender looks so nice and pure without the warts. Just the way Porsche intended. [/quote] OK, just playing devil's advocate, let's say Porsche DID intend to and put warts on 914s originally. Then what would you say now, seeing one without warts? Osnabruck914 |
| wonkipop |
May 26 2023, 03:47 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,751 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
[quote name='Osnabruck914' date='May 25 2023, 05:28 PM' post='3079609']
[/quote] That front fender looks so nice and pure without the warts. Just the way Porsche intended. [/quote] OK, just playing devil's advocate, let's say Porsche DID intend to and put warts on 914s originally. Then what would you say now, seeing one without warts? Osnabruck914 [/quote] i don't think you are playing devil's advocate. the USA side marker regulations were implemented in 1967. there would have been advance notice of the reg with USA domestic and import manufacturers. the 914 would have definitely been designed with side markers in mind from the get go and also with those other countries requiring a side indicator light (turn signal) which is what the j market and italy market cars are. had the 914 for instance been built in a RHD version for australia it would also have required a set up similar to japan. two color front indicator/parking light lenses and a J spec beauty spot. so i believe the side markers are an original design intent - not an afterthought tack on. the use of pure circles is to me consistent with the german no nonsense functional attitude to design. the same thing happened with 924s. you guys got round side marker lights on the 924s. only difference from a 914 was they became flush mounted. they probably could have been flush mounted in the 914 except you could not do a flush mounted indicator unit for japan or italy. porsche designed a universal front light that could either be an indicator or a usa required side marker. the side marker lens was all that was different. later in the 924s the side indicator regs in japan (and australia) and possibly italy had changed to a new position behind the front wheel on the side of the car. our 924s had that side indicator. i believe USA 924s do not have that indicator light. so use of a universal light position for both a side marker and side indicator was no longer possible. 911s are the same as 924s in that regard. australian and japanese lighting regulations on cars parallel each other and have since the early 1960s. the japanese "invasion" started here. australia was the test market for the japanese before they assaulted the USA full scale. here ends the potted history side lamps. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) point being. the side markers are an intended design element. consistent with german design school thinking at that time. ----- and if you happened to live in south africa your car would cop weird little white relflector lenses and rear reflector lenses which were very small and circular. car manufactures had no room to move on those. they had to be circular, had to be a specific size (quite small - about 40mm diam) and mounted within a very tight dimensional envelope. if you ever find a south african built VW they all have them. chevrolets for the SA market were all built here in australia back in the 60s and 70s. they were rebadged holdens. they all had the weirdo reflectors. which could not help but looked tacked on. but again not an afterthought so much as a mandated requirement with no room to move. |
| KELTY360 |
May 26 2023, 11:56 PM
[quote name='wonkipop' date='May 26 2023, 01:47 PM'
point being. the side markers are an intended design element. consistent with german design school thinking at that time. [/quote] If that were true, why were cars in the country of origin designed without the warts? I believe they were added to satisfy regulations of countries which required them. The question kind of gets down to whether they were 'deleted' when not needed or 'added' when they were needed. It doesn't seem like the Germans were inclined to add elements unless necessary. |
| wonkipop |
May 27 2023, 01:51 AM
QUOTE(wonkipop @ May 26 2023, 01:47 PM) 'deleted'[/b] when not needed or 'added' when they were needed. It doesn't seem like the Germans were inclined to add elements unless necessary. i agree. their basic instinct is minimalism. they stole it from the japanese in the early 20th century when they became aware of japanese architecture. mies van der rohe the great german (or should i say chicago) architect needs no introduction or further explanation. they didn't require the side indicators in germany at that time - is the answer to why its not on the german cars. but they did require the two tone euro lenses on the front. which in my humble opinion are "impure" and somewhat non minimalist but nevertheless the min requirement for regulations. i offer that. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) of interest. anything VW or japanese is not really a country of origin car by the 1960s. both countries owe their economic miracle to selling products in the USA to a market that exceeded their own by at least a factor of 10. additionally the 914 was a pan european car. the common market or the EU (take your pick) was in full swing. italy required the side indicators. france its peculiar yellow headlights and yellow rear reversing lights. sweden had some special requirements for which there were additional blobs on the bumpers for windscreen washers. and lets not even mention california------for what it did to the engines. but i think the figure was at that time that 2/3 of the porsches produced were sold in the USA and 50% of those were in california. making it the single biggest market and economy that porsche sold product in. so all i am trying to say is i am sure they placed a good deal of effort into thinking about the side markers in both aesthetic and engineering terms. and came up with something typically german. a nicely placed piece of pure geometry. something very frank, very functional but to my eye not at all ugly. anyway - i can see why you all fit euro lenses and wipe the "warts" off in the USA. its for the same reason i have kept my USA lenses and beauty spots on my car in australia. i was perhaps not so focussed on the warts as i was on the pure orange front lenses. the last thing i wanted was those "ugly" split euro lenses. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) i hid the parker light bulbs in the headlight units and got away with it. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) we all make judgements. the main thing is we all made the judgement of owning a 914. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer.gif) |
Osnabruck914 Spotted In Germany May 24 2023, 11:47 AM
technicalninja I though the round side marker light was a USA onl... May 24 2023, 12:29 PM
I though the round side marker light was a USA on... May 24 2023, 12:38 PM
Steve
I though the round side marker light was a USA o... May 24 2023, 01:51 PM
wonkipop
I though the round side marker light was a USA on... May 25 2023, 03:33 AM
Osnabruck914 It's strange how tastes differ. I find the ... May 24 2023, 04:43 PM
wonkipop
It's strange how tastes differ. I find the ... May 25 2023, 03:31 AM
Literati914 Italian turn signals, the plot thickens! BTW, ... May 24 2023, 05:22 PM
Gustl due to the small front license plate and the ... May 24 2023, 09:47 PM
KELTY360
That front fender looks so nice and pure withou... May 25 2023, 08:09 PM
wonkipop as a afterthought to above, it may have been inten... May 26 2023, 03:56 PM
wonkipop ps @KELTY360
i see you like your pure orange le... May 27 2023, 02:06 AM
wonkipop @KELTY360
i don't want to flog the subject.
... May 27 2023, 02:35 AM
Van B Fun fact wonki, engineers had to redesign the gun ... May 27 2023, 08:25 AM
wonkipop
Fun fact wonki, engineers had to redesign the gun... May 28 2023, 12:22 AM
KELTY360
Fun fact wonki, engineers had to redesign the gu... May 28 2023, 06:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th October 2026 - 02:14 AM |
