> Replaced Fuel Pump, Replacement Pump Run Backwards
jrrobertson
post May 28 2023, 07:35 PM
The fuel pump (0580 463 009) on my 71 quit working. Even with power connected directly to the pump it did not work. I replaced it with a spare pump (0580 463 005) I had. This one only builds pressure if I switch the positive and negative leads. It will run when connected normally but it will run backwards and will push fuel down the return line. Anyone have any ideas as to why this is? The car runs OK with the wires switched.
The car has the original D-jet fuel injection system.
930cabman
post May 29 2023, 06:11 AM
Switch the + and the - terminals on the pump. I recently had the same issue with an aftermarket pump.
- Lo-Fi Version Time is now: 16th July 2025 - 04:23 PM
