> Gaps between engine tin and engine bay gaskets., Trying to figure out how to close them.
Chaznaster
post May 29 2023, 06:33 PM
I put my engine back in today for the first time.
It went pretty well but have a gap between the tin and seals on the left and right towards the front. It is about 1/2" on the L and 3/8" on the right. I installed brand new seals from 914Rubber but they do not bridge the gap. The tin is also pretty far above the lip in the seal where it should contact the tin. Not sure about the metal staples/clips that came with the seals - are they used to close gaps like the ones in the pics?
Or ... another thought: the engine looks like it might be a little too far forward. Moving it back should help close the gap, at least where the curve is. Should/ can I loosen the bolts holding on the crossbar and the big bolts where the transmission attaches to the mounts and pull it all back a bit?
Thanks for your thoughts on this ...
gonzo54
post May 29 2023, 08:45 PM
Orange Crush
I have encountered the same problem after my recent enigne rebuild and installation. Rubber seals are from the same vendor with new motor mounts and transmission mounts. I thought the motor mounts might not be the correct P/N or height but the P/N is correct. So is the engine to low for the tin to hook up the the seals?
- Lo-Fi Version Time is now: 4th November 2026 - 06:33 AM
