| Tdskip |
May 25 2023, 07:21 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,784 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Good morning.
I managed to track down a couple pair of 3 inch caliper spacing Brembos. I started to do some initial fitment validation and realized that one pair fits perfectly on a vented front disk 3 inch caliper spacing whereas the other fits the same 3 inch caliper spacing perfectly but has too narrow of an opening where the disc goes so it’ll only work on unvented brake rotors. Any tips or coaching here on with the narrower pair will fit – is it simply a matter of needing an earlier non-vented from brake set up? In other words, one pair works fine with a 911 SC brake set up and I’m assuming the other pair should be fine with a non-vented 914 rotor? Thanks. |
| jcd914 |
Jun 1 2023, 11:17 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I have 3 pair of the Alfa Brembo calipers and they all have spacers that measure approx 9mm thick.
If you are going 5 lug suspension you could run solid rotors from early 911/912 or you could run them on 914 solid rotors. 914 solid rotors are 10mm thick, 911/912 solid rotors are 12mm thick. I previously ran 912 calipers on my 71 914-4 solid rotors and they worked good but I could over heat them. Jim |
Tdskip Yes, Brembo questions. Again. May 25 2023, 07:21 AM
914Sixer Maybe Eric Shea will chime in. Spacers may have b... May 25 2023, 08:26 AM
Tdskip Thanks for the response. They actually have remove... May 25 2023, 10:31 AM
mepstein I’m pretty sure they work with solid 5 lug rotor... May 25 2023, 10:35 AM
eeyore I have stock early 911 solid rotors on my 5 lug co... May 25 2023, 10:35 AM
jim_hoyland Where do you the caliper spacers ? May 25 2023, 08:48 PM
Tdskip Thanks for the discussion.
I wasn’t as clear as... May 25 2023, 10:00 PM
PatMc
I wasn’t as clear a... May 26 2023, 07:22 AM
Tdskip
I wasn’t as clear ... May 26 2023, 08:17 AM
Krieger
I wasn’t as clear ... May 26 2023, 08:23 AM
I wasn’t as clear ... May 26 2023, 09:03 AM
Tdskip OK - took a while but am back with the program tha... May 27 2023, 05:55 AM
Tdskip Thanks for the discussion gentlemen.
Any tips on ... Jun 1 2023, 06:44 AM
Any tips on... Jun 1 2023, 08:31 AM
Krieger
Any tips o... Jun 1 2023, 09:48 AM
Krieger Maybe PMB has an extra set. They did buy a stash ... Jun 1 2023, 07:23 AM
Literati914 As a first step, contact the person you got the no... Jun 1 2023, 09:52 AM
As a first step, contact the person you got the n... Jun 1 2023, 11:13 AM
Literati914
.. In other words, one pair works fine with a 911... Jun 1 2023, 11:22 AM
Eric_Shea We should have extra spacers and fasteners Jun 1 2023, 02:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th November 2026 - 07:21 PM |
