> Copper flanged exhaust nuts, DO NOT USE THEM
VaccaRabite
post Jun 3 2023, 07:56 PM
En Garde!
I have never pulled an exhaust stud before while doing pipes. This evening I’m 4 for 4. These copper flanged nuts locked on the studs and there was 100% no getting them off without the studs coming with them.
Going back to using just regular nuts with 12mm flats. So much for trying to get the “right” part.
Edit to add details:
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1685976726.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1685976727.2.jpg)
The nuts in question are commonly available and sold as exhaust nuts. I got mine from Auto Atlanta - but many places sell them. The have a copper color to them and the bore is slightly oval. The are designed to lock on to the stud - which I did not know at the time. They go on tight and you can not remove them without pulling the stud.
There are flanged nuts that work fine.
Kinda furious with myself right now.
Continuing to live life as an object lesson for others…
Zach
VaccaRabite   Copper flanged exhaust nuts   Jun 3 2023, 07:56 PM
bkrantz   Did you use anti-seize?   Jun 3 2023, 08:20 PM
VaccaRabite   Did you use anti-seize? High temp copper antisei...   Jun 3 2023, 08:22 PM
mgphoto   Did you use anti-seize? Doesn’t matter, they a...   Jun 3 2023, 08:23 PM
Root_Werks   Did you use anti-seize? Doesn’t matter, they ...   Jun 5 2023, 11:24 AM
VaccaRabite   Car started popping a lot on decel today while I w...   Jun 3 2023, 08:26 PM
mgphoto   Car started popping a lot on decel today while I ...   Jun 3 2023, 09:09 PM
r_towle   Or Headers and exhaust from Foley?   Jun 3 2023, 09:15 PM
VaccaRabite   Or Headers and exhaust from Foley? I eventually...   Jun 3 2023, 09:37 PM
r_towle   I thought it had heat? If you are jammed I will g...   Jun 3 2023, 11:01 PM
mepstein   I thought it had heat? If you are jammed I will ...   Jun 4 2023, 04:35 AM
ClayPerrine   There is an Aluminized Mercedes Benz flanged exhau...   Jun 4 2023, 06:53 AM
porschetub   There is an Aluminized Mercedes Benz flanged exha...   Jun 4 2023, 07:34 PM
rhodyguy   Are those the VW style ones? With the slightly ova...   Jun 4 2023, 07:08 AM
rhodyguy   I think you will find 8 of these more to your liki...   Jun 4 2023, 09:08 AM
JamesM   I think you will find 8 of these more to your lik...   Jun 4 2023, 01:35 PM
DC_neun_vierzehn   [quote name='rhodyguy' post='3081595' date='Jun 4...   Jun 4 2023, 03:48 PM
sixnotfour   [quote name='rhodyguy' post='3081595' date='Jun ...   Jun 4 2023, 03:53 PM
sixnotfour   Im not a type 4 guy , But Ive seen more cracked SS...   Jun 4 2023, 09:24 AM
rhodyguy   Torqueing the shit out of the nuts, to cure a leak...   Jun 4 2023, 09:30 AM
VaccaRabite   Torqueing the shit out of the nuts, to cure a lea...   Jun 4 2023, 06:51 PM
iankarr   Just curious…is there a mechanical issue with th...   Jun 4 2023, 09:41 PM
VaccaRabite   Just curious…is there a mechanical issue with t...   Jun 5 2023, 07:23 AM
rhodyguy   A MAJOR pain! Then you go shopping for step up...   Jun 5 2023, 07:33 AM
ClayPerrine   Years ago I had to have a head welded up the night...   Jun 5 2023, 07:41 AM
930cabman   Years ago I had to have a head welded up the nigh...   Jun 6 2023, 12:33 PM
ClayPerrine   [quote name='ClayPerrine' post='3081838' date='Ju...   Jun 6 2023, 01:18 PM
VaccaRabite   http://www.914world.com/bbs2/uploads_offsite/live....   Jun 5 2023, 08:40 AM
MartyYeoman   It's also important to watch that there's ...   Jun 5 2023, 10:28 AM
Jim C   Wish I had know this last weekend.   Jun 5 2023, 12:02 PM
r_towle   In a DM I said, and I would love to see, stub pipe...   Jun 5 2023, 02:20 PM
rjames   In a DM I said, and I would love to see, stub pip...   Jun 5 2023, 04:20 PM
IronHillRestorations   All the copper coated flange nuts that I’ve seen...   Jun 6 2023, 10:58 AM
Literati914   I think you will find 8 of these more to your lik...   Apr 21 2024, 08:20 PM
rhodyguy   r not R.   Apr 22 2024, 02:39 PM
technicalninja   That means there's two of you! A pair of ...   Apr 22 2024, 02:51 PM
rhodyguy   Nope. Not that I’m aware of.   Apr 22 2024, 03:57 PM
- Lo-Fi Version Time is now: 13th November 2026 - 12:36 PM
