| VaccaRabite |
Jun 3 2023, 07:56 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,939 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I have never pulled an exhaust stud before while doing pipes. This evening I’m 4 for 4. These copper flanged nuts locked on the studs and there was 100% no getting them off without the studs coming with them. Going back to using just regular nuts with 12mm flats. So much for trying to get the “right” part. Edit to add details: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1685976726.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1685976727.2.jpg) The nuts in question are commonly available and sold as exhaust nuts. I got mine from Auto Atlanta - but many places sell them. The have a copper color to them and the bore is slightly oval. The are designed to lock on to the stud - which I did not know at the time. They go on tight and you can not remove them without pulling the stud. There are flanged nuts that work fine. Kinda furious with myself right now. Continuing to live life as an object lesson for others… Zach |
| r_towle |
Jun 3 2023, 09:15 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Or
Headers and exhaust from Foley? |
| VaccaRabite |
Jun 3 2023, 09:37 PM
VaccaRabite Copper flanged exhaust nuts Jun 3 2023, 07:56 PM
bkrantz Did you use anti-seize? Jun 3 2023, 08:20 PM
VaccaRabite
High temp copper antisei... Jun 3 2023, 08:22 PM
mgphoto
Doesn’t matter, they a... Jun 3 2023, 08:23 PM
Root_Werks
Doesn’t matter, they ... Jun 5 2023, 11:24 AM
VaccaRabite Car started popping a lot on decel today while I w... Jun 3 2023, 08:26 PM
mgphoto
Car started popping a lot on decel today while I ... Jun 3 2023, 09:09 PM
r_towle I thought it had heat?
If you are jammed I will g... Jun 3 2023, 11:01 PM
If you are jammed I will ... Jun 4 2023, 04:35 AM
ClayPerrine There is an Aluminized Mercedes Benz flanged exhau... Jun 4 2023, 06:53 AM
porschetub
There is an Aluminized Mercedes Benz flanged exha... Jun 4 2023, 07:34 PM
rhodyguy Are those the VW style ones? With the slightly ova... Jun 4 2023, 07:08 AM
rhodyguy I think you will find 8 of these more to your liki... Jun 4 2023, 09:08 AM
JamesM
I think you will find 8 of these more to your lik... Jun 4 2023, 01:35 PM
DC_neun_vierzehn
[quote name='rhodyguy' post='3081595' date='Jun 4... Jun 4 2023, 03:48 PM
sixnotfour
[quote name='rhodyguy' post='3081595' date='Jun ... Jun 4 2023, 03:53 PM
sixnotfour Im not a type 4 guy , But Ive seen more cracked SS... Jun 4 2023, 09:24 AM
rhodyguy Torqueing the shit out of the nuts, to cure a leak... Jun 4 2023, 09:30 AM
VaccaRabite
Torqueing the shit out of the nuts, to cure a lea... Jun 4 2023, 06:51 PM
iankarr Just curious…is there a mechanical issue with th... Jun 4 2023, 09:41 PM
VaccaRabite
Just curious…is there a mechanical issue with t... Jun 5 2023, 07:23 AM
rhodyguy A MAJOR pain! Then you go shopping for step up... Jun 5 2023, 07:33 AM
ClayPerrine Years ago I had to have a head welded up the night... Jun 5 2023, 07:41 AM
930cabman
Years ago I had to have a head welded up the nigh... Jun 6 2023, 12:33 PM
ClayPerrine
[quote name='ClayPerrine' post='3081838' date='Ju... Jun 6 2023, 01:18 PM
VaccaRabite http://www.914world.com/bbs2/uploads_offsite/live.... Jun 5 2023, 08:40 AM
MartyYeoman It's also important to watch that there's ... Jun 5 2023, 10:28 AM
Jim C Wish I had know this last weekend. Jun 5 2023, 12:02 PM
r_towle In a DM I said, and I would love to see, stub pipe... Jun 5 2023, 02:20 PM
rjames
In a DM I said, and I would love to see, stub pip... Jun 5 2023, 04:20 PM
IronHillRestorations All the copper coated flange nuts that I’ve seen... Jun 6 2023, 10:58 AM
Literati914
I think you will find 8 of these more to your lik... Apr 21 2024, 08:20 PM
rhodyguy r not R. Apr 22 2024, 02:39 PM
technicalninja That means there's two of you!
A pair of ... Apr 22 2024, 02:51 PM
rhodyguy Nope. Not that I’m aware of. Apr 22 2024, 03:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th November 2026 - 12:36 PM |
