@StarBear L Jetronic Temp Sensor II AFM |
wonkipop |
Jun 5 2023, 03:12 PM
Advanced Member Group: Members Posts: 4,403 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
@StarBear .
here is what i have on the Temp Sensor II inbuilt into the AFM on the 1.8 L Jetronic. i could be wrong but i don't think there is any effective way to test the air temp sensor in the AFM on our adam/eve in the garden of eden L Jetronic system. that sensor is not wired in separately. but maybe there is an expert here who knows. - in relation to the problem you are having with hot days and ultra high humidity causing the idle to drop to barely running - i'm not sure the symptom fits a faulty Temp Sensor II in the AFM. others here might know better. I would not have thought a faulty sensor would cause that dramatic a result. Temp Sensor 1 (CHT) - yes. but Temp Sensor II no. i am sure @Van B will pipe in with a more learned view. I would have thought Temp Sensor 2 fault would make the car run rich. I think that is how it would work. but again i am probably wrong. i'd have to think about it. most trouble shooting literature i can dig up says failure mode causes car to run richer generally. increased fuel consumption. |
StarBear |
Jun 5 2023, 07:50 PM
Senior Member Group: Members Posts: 1,914 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Got it! Will add to my other write up and collect some data! The game is afoot….
Lo-Fi Version | Time is now: 11th June 2024 - 08:02 AM |
