@StarBear L Jetronic Temp Sensor II AFM |
wonkipop |
Jun 5 2023, 03:12 PM
Advanced Member Group: Members Posts: 4,403 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
@StarBear .
here is what i have on the Temp Sensor II inbuilt into the AFM on the 1.8 L Jetronic. i could be wrong but i don't think there is any effective way to test the air temp sensor in the AFM on our adam/eve in the garden of eden L Jetronic system. that sensor is not wired in separately. but maybe there is an expert here who knows. - in relation to the problem you are having with hot days and ultra high humidity causing the idle to drop to barely running - i'm not sure the symptom fits a faulty Temp Sensor II in the AFM. others here might know better. I would not have thought a faulty sensor would cause that dramatic a result. Temp Sensor 1 (CHT) - yes. but Temp Sensor II no. i am sure @Van B will pipe in with a more learned view. I would have thought Temp Sensor 2 fault would make the car run rich. I think that is how it would work. but again i am probably wrong. i'd have to think about it. most trouble shooting literature i can dig up says failure mode causes car to run richer generally. increased fuel consumption. |
ClayPerrine |
Jun 6 2023, 06:33 AM
Life's been good to me so far..... Group: Admin Posts: 15,525 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Temp sensor 2 is used for gross fuel adjustments.. aka warmup. After the engine is warm and the resistance is below a certain point, the ECU, for the most part, ignores it. I had one fail on a hot engine, and I just grounded the wire to make the ECU see a low resistance signal. I was able to drive it home like that.
Temp sensor 1 is the fine tuning for the mixture based on temp. It is always on, and measuring the temp of the intake air to trim the fuel mixture. I have not done this, as I don't see the value in it. But the temp sensor 1 was the same all the way through the AFM on the 964, and with the move in favor of a MAF sensor 993, it became a separate part. So theoretically, you could get the air temp sender for a 993 and put it in the air flow somewhere and wire it into the harness. That being said, there are LOTS of original L-Jet AFMs out there. So there really isn't a point in reinventing the wheel. |
Lo-Fi Version | Time is now: 11th June 2024 - 10:51 AM |
