| engine247 |
Jun 26 2023, 09:21 AM
Newbie ![]() Group: Members Posts: 9 Joined: 2-June 22 From: Austin Member No.: 26,590 Region Association: Southwest Region |
Howdy,
I noticed a newish leak under the car. So I clean up the bottom best I could and let it sit for a bit. The leak appears to just seep through the case slowly but consistently. Maybe a defect or small crack? I'm wondering what my options are here? Only solved with a new case or is there a band aid until this can be bundled with other related maintenance? Cheers. |
| technicalninja |
Jun 26 2023, 11:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
2nd on the JB weld.
Biggest trick is to get the cracked alloy housing clean! I once repaired a Toyota cylinder head blow out between chambers with JB weld. The missing section was the size of my little finger between #1 and 2. I advised customer (a good friend) that it would last 6 minutes... Long enough to take it to CarMax or another dealer. It actually lasted 11 months and 16K miles before it shit the bed a second time. I was shocked! JB weld as an integral part of two combustion chambers! Larry (my friend) had won a 7-figure lawsuit by that time, and they just threw the car away... |
engine247 Transmission Case Leak Jun 26 2023, 09:21 AM
Shivers I wrenched motorcycles in the day. The Honda cb 75... Jun 26 2023, 09:30 AM
rjames Looks like it's leaking at the output shaft se... Jun 26 2023, 09:43 AM
engine247 Yeah, I thought it would have been from a seal but... Jun 26 2023, 09:55 AM
rjames Are you sure? Where the drip shows is just the low... Jun 26 2023, 10:34 AM
930cabman Also back in the day, ...... no need to explain, b... Jun 26 2023, 11:17 AM
ClayPerrine There is a known long term issue with porosity in ... Jun 26 2023, 11:20 AM
engine247 @rjames I hear what you are saying so I've do... Jun 27 2023, 03:32 PM
Robarabian I think if you want to seal it with JB and it is f... Jun 27 2023, 04:37 PM
rjames
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 27 2023, 05:07 PM
wndsrfr
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 27 2023, 08:48 PM
engine247 Just to follow up on this issue. I did drain the g... Aug 30 2023, 09:43 PM
930cabman
Just to follow up on this issue. I did drain the ... Aug 31 2023, 04:57 AM
mepstein Porsche had a porosity issue on their mag engine c... Aug 31 2023, 05:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 09:49 PM |
