> HELP: Removing Axle's/CV joints from trailing arms, what tricks or secrets in removing them? I can't get mine off...Grrrr
Mr.242
post Oct 27 2011, 09:55 PM
May your glass be smaller so it's always FULL!
Having removed the Engine and Tranny. Prep for the car to head to the paint process. I want to remove and rebuild the axle and CV joints.
I can't get them to come loose. Am I missing something?
(IMG:style_emoticons/default/pray.gif) Any help would be appreciated. Thanks!
Geezer914
post Jul 8 2023, 03:31 PM
Geezer914
There is a you tube video that an older VW mechanic made on how to remove everything and replace the bearing. Porsche 914 how to replace the rear axle bearing part 1 & 2. He made a home made slide hammer. Ian Karr's video, you remove the 30mm nut and put it on backwards flush with the axle and smack it with a BFH to knock the axle out. Looks like a lot of rust around the washer, soak that area with some PB blaster over night.
Mr.242   HELP: Removing Axle's/CV joints from trailing arms   Oct 27 2011, 09:55 PM
rwilner   Assuming you removed the 4 12-star bolts, you can ...   Oct 27 2011, 10:06 PM
jcd914   If you remove the stub axles don't roll the ca...   Oct 27 2011, 10:16 PM
JRust   Having removed the Engine and Tranny. Prep for t...   Oct 27 2011, 10:24 PM
Cap'n Krusty   Having removed the Engine and Tranny. Prep for ...   Oct 27 2011, 11:28 PM
Mr.242   I am pulling and pounding like crazy on these....w...   Oct 27 2011, 10:30 PM
Elliot Cannon   I am pulling and pounding like crazy on these.......   Oct 27 2011, 10:31 PM
Mr.242   Some pictures might help. Show us what you...   Oct 27 2011, 11:12 PM
Mr.242   Okay, Okay, Okay.....I couldn't resist. Here ...   Oct 27 2011, 11:19 PM
nathansnathan   Okay, Okay, Okay.....I couldn't resist. Here...   Oct 28 2011, 07:06 AM
Mr.242   So I have asked: What is it that YOU do to get th...   Oct 28 2011, 07:03 AM
vsg914   So I have asked: What is it that YOU do to get t...   Oct 28 2011, 07:31 AM
rohar   Just a sec, it isn't quite clear. You trying ...   Oct 28 2011, 08:13 AM
rohar   If you're trying to remove the axle with the s...   Oct 28 2011, 08:39 AM
jimkelly   mr.242 - firstly congrats ; )) secondly - have yo...   Oct 28 2011, 08:49 AM
stugray   He is just trying to separate the CV from the stub...   Oct 28 2011, 09:38 AM
jcd914   He is just trying to separate the CV from the stu...   Oct 28 2011, 09:48 AM
vsg914   He is just trying to separate the CV from the st...   Oct 28 2011, 10:27 AM
tradisrad   [quote name='jcd914' post='1562816' date='Oct 28 ...   Nov 28 2011, 12:10 PM
zx-niner   He is just trying to separate the CV from the st...   Oct 29 2011, 12:09 PM
rjames   How old are your rear bearings? If you think they ...   Oct 28 2011, 09:55 AM
Jeffs9146   I wrap a comealong around the axel and the trailin...   Oct 28 2011, 10:56 AM
vsg914   I wrap a comealong around the axel and the traili...   Oct 28 2011, 11:09 AM
Jeffs9146   Deleted   Oct 28 2011, 10:57 AM
Tom   Call Mike, hasn't he done this? Pretty sure...   Oct 28 2011, 12:47 PM
stugray   "Pretty sure you can remove the whole axle wi...   Oct 28 2011, 03:21 PM
Mr.242   I wrap a comealong around the axel and the traili...   Oct 29 2011, 11:26 AM
Jeffs9146   I wrap a comealong around the axel and the trail...   Oct 29 2011, 11:51 AM
Dr Evil   The only thing holding it on at this point are two...   Oct 29 2011, 12:15 PM
Mr.242   The only thing holding it on at this point are tw...   Oct 29 2011, 12:48 PM
Mr.242   Well they are OFF. I had to have Mike come over w...   Nov 28 2011, 10:26 AM
SirAndy   All those other methods didn't work and after ...   Nov 28 2011, 08:27 PM
6freak   he just needed to call big brother with the right ...   Nov 28 2011, 10:52 AM
6freak   [ the right tools :) just so ya know a Dewalt ...   Nov 28 2011, 01:39 PM
JRust   [ the right tools :) just so ya know a Dewalt 1...   Nov 28 2011, 02:44 PM
6freak   [ the right tools :) just so ya know a Dewalt ...   Nov 29 2011, 08:55 AM
PeeGreen 914   he just needed to call big brother with the right...   Nov 28 2011, 06:00 PM
tod914   Alittle late to respond. But, after struggeling wi...   Nov 28 2011, 04:22 PM
Mr.242   he just needed to call big brother with the righ...   Nov 28 2011, 08:20 PM
Mr.242   All those other methods didn't work and after...   Nov 28 2011, 10:35 PM
jhynesrockmtn   Thankful to have found this older thread. Just pu...   Jul 8 2023, 02:51 PM
Geezer914   There is a you tube video that an older VW mechani...   Jul 8 2023, 03:31 PM
- Lo-Fi Version Time is now: 4th September 2026 - 11:55 PM
