CV service/replacement decision |
jhynesrockmtn |
Jul 11 2023, 09:41 AM
Member Group: Members Posts: 420 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I am going through my Bumblebee system by system. The front suspension is close to finished. The motor is out to chase down some minor leaks, redo the RMS and trans output shaft seal and inspect the clutch components. I'll also be adding a 123 distributor, refreshed injectors, Bowlsby harnesses, Foley SS fuel lines, new soft fuel lines and vacuum lines, valve adjust, etc.
My question is about the CV joints. The grease looks like crap. One side was missing a gasket, several bolts were loose. I am leaning toward buying the replacement CV joints from PMB. Has anyone installed these? I'd like to keep these axles and go through them to learn, inspect and possibly use them on my 1970. What would you do? https://pmbperformance.com/products/porsche...ro-cv-joint-kit |
North Coast Jim |
Jul 11 2023, 10:44 AM
Member Group: Members Posts: 326 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
I am going through my Bumblebee system by system. The front suspension is close to finished. The motor is out to chase down some minor leaks, redo the RMS and trans output shaft seal and inspect the clutch components. I'll also be adding a 123 distributor, refreshed injectors, Bowlsby harnesses, Foley SS fuel lines, new soft fuel lines and vacuum lines, valve adjust, etc. My question is about the CV joints. The grease looks like crap. One side was missing a gasket, several bolts were loose. I am leaning toward buying the replacement CV joints from PMB. Has anyone installed these? I'd like to keep these axles and go through them to learn, inspect and possibly use them on my 1970. What would you do? https://pmbperformance.com/products/porsche...ro-cv-joint-kit Porsche has re-released these items. Buy new. I tried to rebuild mine and came up with marginal results. Old parts are high mileage and show it. |
Lo-Fi Version | Time is now: 11th June 2024 - 11:50 AM |
