Deck height, compression ratio, and valve relief flat top pistons, In a 2.0 |
emerygt350 |
Jul 13 2023, 11:41 AM
Advanced Member Group: Members Posts: 2,139 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Ok, my question of the day:
Put my new 96mm pistons and cylinders on and measured deck height, .033 all the way around. Let's say .032 to be conservative. I will not be running head gaskets. The calculator gives me 8.8 CR at .033 8.6 CR at .043 8.4 CR at .053 The pistons have a valve relief (pretty large) cut. I am shooting for 8.4 CR. Heads are in the shop so I can't check the CC yet. Everything I read says .04 - .06 for deck height. With the valve relief do I need to worry about going lower? If I had dishes would you measure from the edge of the piston or the dish? |
rfinegan |
Jul 13 2023, 12:31 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
O.040 deck height is considered the minimum deck height for t-4 engines. Sure you can go lower or shim the bottoms of the cylinders to increase or decrease the CR(compression ratio)
However the area between the bottom of the head and the top of the piston will determine the squish area. Too tight, you will restrict the flame-front travel and really hurt performance. some reference on squish: https://www.thesamba.com/vw/forum/viewtopic.php?p=8865130 |
Lo-Fi Version | Time is now: 7th June 2024 - 10:54 AM |
