Leaking oil, pump |
Leaking oil, pump |
930cabman |
Jul 16 2023, 05:15 PM
Advanced Member Group: Members Posts: 3,167 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Fresh 2056 (2022) engine is running well, but a pesky oil leak has been a down side from day one. Need to be careful if parking at a friends (or enemies) driveway. I don't have 100% cure, but I have isolated it to the front seal/oil pump area over the past couple weeks. I was determined to find it this weekend and removed the engine bar, propped the engine up with a 4x4 and warmed her up good. It took awhile (170 ish oil temp) to get a leak going, but the studs/nuts holding the oil pump cover were leaking. The front seal area looks great, the gasket(s) between the oil pump/case and oil pump/cover look good also. Hopefully new sealing washers and sealing nuts will get things dried up.
rfinegan |
Jul 17 2023, 09:44 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
VW Oil Pump Cover Plate Sealing Nut - 8mm
https://www.jbugs.com/product/111115161.htm...soaArqHEALw_wcB These worked well on the T-1 30mm pump and put them on my t4 pump too |
930cabman |
Jul 17 2023, 12:04 PM
VW Oil Pump Cover Plate Sealing Nut - 8mm https://www.jbugs.com/product/111115161.htm...soaArqHEALw_wcB These worked well on the T-1 30mm pump and put them on my t4 pump too Got em, they are on the way. Along with a soft (crush) washer, it should do the trick |
bkrantz |
Jul 17 2023, 07:52 PM
914 Guru Group: Members Posts: 7,808 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
VW Oil Pump Cover Plate Sealing Nut - 8mm https://www.jbugs.com/product/111115161.htm...soaArqHEALw_wcB These worked well on the T-1 30mm pump and put them on my t4 pump too Got em, they are on the way. Along with a soft (crush) washer, it should do the trick I would suggest the sealing nuts without washers--on mine the nuts have sealed without problems. But they are single use. |
Lo-Fi Version | Time is now: 12th June 2024 - 09:04 AM |
