| NARP74 |
Jul 17 2023, 09:08 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,448 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
My car was disassembled for painting many years ago and put together hastily. Most things I dig into need hardware, or adjusting or replacement. The front trunk handle is the latest.
It never looked like a stock handle should. There is a chrome cylinder, 5mm to 6mm in diameter sticking up a bit from the handle. That stops the handle from going into the handle mount so the whole handle sticks out a bit and wobbles. When I took it apart, I noticed the small stop screw on the handle slider is not installed. It does function correctly, just with a wobbly handle in the holder, the holder mount is tight to the car body. Questions Do I just press that small chrome cylinder down until it is even on both sides? What does it do? What are the specs for that stop screw? Cant see any details in the PET. Will I have adjust the cable or sleeve when I get it put back together correctly. Cheers |
| TheCabinetmaker |
Jul 18 2023, 10:23 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,367 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Pm me please. I have what you need, and can walk you through this. Not a big deal
NARP74 Frunk Handle Jul 17 2023, 09:08 AM
NARP74 Wow! I did not know I was playing stump the W... Jul 17 2023, 04:03 PM
Jamie
Wow! I did not know I was playing stump the ... Jul 17 2023, 05:43 PM
Front yard mechanic I’ll comment that handle needs some ghetto paint... Jul 17 2023, 05:19 PM
NARP74
I’ll comment that handle needs some ghetto pain... Jul 17 2023, 05:37 PM
NARP74 1974 Jul 17 2023, 05:53 PM
fixer34 Maybe a picture of the other side of it?? Jul 17 2023, 06:16 PM
NARP74 It's the same handle I have seen in most later... Jul 17 2023, 06:29 PM
L-Jet914 @NARP74 Went out into the garage. Here is what mi... Jul 17 2023, 06:50 PM
L-Jet914 second photo of orientation of the release handle ... Jul 17 2023, 06:51 PM
GregAmy See if anything here helps
http://www.914world.co... Jul 17 2023, 06:53 PM
East coaster Is it just locked? Looks like the lock pin is out ... Jul 17 2023, 07:14 PM
Root_Werks
Is it just locked? Looks like the lock pin is out... Jul 18 2023, 09:46 AM
NARP74
Is it just locked? Looks like the lock pin is ou... Jul 18 2023, 09:55 AM
NARP74 @L-Jet914 thanks for the pics, that is what I am ... Jul 17 2023, 08:18 PM
r_towle 42 Jul 17 2023, 08:21 PM
NARP74
42
The ultimate answer? Jul 18 2023, 08:08 AM
StarBear
42
Yes, but what’s the ... Jul 18 2023, 08:35 AM
NARP74 No way to write this without it sounding like a st... Jul 18 2023, 08:11 AM
NARP74 Looking for info on this screw. Where the screwdr... Jul 18 2023, 11:41 AM
partwerks
Looking for info on this screw. Where the screwd... Aug 12 2023, 10:00 PM
NARP74 I have been told by @TheCabinetmaker that the sp... Jul 18 2023, 12:40 PM
NARP74 Well, I have a good update and an epic fail update... Jul 29 2023, 01:24 PM
mepstein You remove the front bumper and stick a flat blade... Jul 29 2023, 01:35 PM
NARP74 I think my fiberglass bumper is mounted from the f... Jul 29 2023, 01:38 PM
I think my fiberglass bumper is mounted from the ... Jul 29 2023, 01:40 PM
NARP74 And I have an oil cooler in that area... Jul 29 2023, 01:44 PM
TheCabinetmaker The cable must be screwed in till it stops. The ad... Jul 29 2023, 02:16 PM
NARP74 Sounds like I have some work ahead of me. I think... Jul 29 2023, 07:50 PM
NARP74 I think I figured out what might have happened. B... Jul 30 2023, 09:32 AM
NARP74 I'm in! Necessity is the mother of all sh... Jul 30 2023, 10:08 AM
TheCabinetmaker Broken sheath repair. 914 rubber has them, I think... Jul 30 2023, 10:23 AM
NARP74 That is where I got the idea that the sheath was j... Jul 30 2023, 10:33 AM
NARP74 MvbQ4wJak_c
Channeling Kevin Kline here...
So wh... Aug 12 2023, 08:12 PM
NARP74 Have it, thanks. Specific details are in a post a... Aug 13 2023, 07:03 AM
Mikey914
[youtube]MvbQ4wJak_c
Channeling Kevin Kline her... Aug 13 2023, 08:59 AM
NARP74 Msg sent, thanks Aug 13 2023, 10:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th March 2026 - 07:15 PM |
