Inconsistent voltage, Not very electrifying |
iankarr |
Jul 24 2023, 10:09 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
Trying to sort through a puzzling situation. My car started bucking like a bronco(D-jet) and I noticed that the voltage was super low (like 10). I fortunately made it home. Changed out the voltage regulator with one I had in my bin and everything seemed to be fine. 13.5 when running, no more bucking. Now I'm seeing that the voltage is inconsistent again. Sometimes it's 13.5 when running, then it dips to around 12, then comes back up. Occasionally the red light will come on for a few seconds, even when running at 3K rpm. When I put the headlights on, the idle drops by 500rpm and stumbles. The belt is tight and the alternator was (supposedly) rebuilt recently. Anyway...my thinking is it can only be one of four things: – Bulb in the cluster (unlikely, but possible). I believe it's stock. – Voltage regulator – Alternator – Battery Do you guys have any simple tests i can run to eliminate any of the above before I just start throwing parts at this? Other thoughts? Thanks! |
VaccaRabite |
Jul 24 2023, 02:57 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Feel under the engine relay baord to make sure you have not pushed one of the spades through the potting so its getting an intermittent connection. Been there.
Also, grounds as previously stated. Zach |
Lo-Fi Version | Time is now: 1st June 2024 - 03:51 AM |
