> Frunk Handle, What a mess
NARP74
post Jul 17 2023, 09:08 AM
My car was disassembled for painting many years ago and put together hastily. Most things I dig into need hardware, or adjusting or replacement. The front trunk handle is the latest.
It never looked like a stock handle should. There is a chrome cylinder, 5mm to 6mm in diameter sticking up a bit from the handle. That stops the handle from going into the handle mount so the whole handle sticks out a bit and wobbles. When I took it apart, I noticed the small stop screw on the handle slider is not installed.
It does function correctly, just with a wobbly handle in the holder, the holder mount is tight to the car body.
Questions
Do I just press that small chrome cylinder down until it is even on both sides? What does it do?
What are the specs for that stop screw? Cant see any details in the PET.
Will I have adjust the cable or sleeve when I get it put back together correctly.
Cheers
NARP74
post Jul 29 2023, 07:50 PM
Sounds like I have some work ahead of me. I think the oil cooler mount hardware has nylocks on them, inside the frunk. Might be time for a nutsert tool.
NARP74   Frunk Handle   Jul 17 2023, 09:08 AM
NARP74   Wow! I did not know I was playing stump the W...   Jul 17 2023, 04:03 PM
Jamie   Wow! I did not know I was playing stump the ...   Jul 17 2023, 05:43 PM
Front yard mechanic   I’ll comment that handle needs some ghetto paint...   Jul 17 2023, 05:19 PM
NARP74   I’ll comment that handle needs some ghetto pain...   Jul 17 2023, 05:37 PM
NARP74   1974   Jul 17 2023, 05:53 PM
fixer34   Maybe a picture of the other side of it??   Jul 17 2023, 06:16 PM
NARP74   It's the same handle I have seen in most later...   Jul 17 2023, 06:29 PM
L-Jet914   @NARP74 Went out into the garage. Here is what mi...   Jul 17 2023, 06:50 PM
L-Jet914   second photo of orientation of the release handle ...   Jul 17 2023, 06:51 PM
GregAmy   See if anything here helps http://www.914world.co...   Jul 17 2023, 06:53 PM
East coaster   Is it just locked? Looks like the lock pin is out ...   Jul 17 2023, 07:14 PM
Root_Werks   Is it just locked? Looks like the lock pin is out...   Jul 18 2023, 09:46 AM
NARP74   Is it just locked? Looks like the lock pin is ou...   Jul 18 2023, 09:55 AM
NARP74   @L-Jet914 thanks for the pics, that is what I am ...   Jul 17 2023, 08:18 PM
r_towle   42   Jul 17 2023, 08:21 PM
NARP74   42 The ultimate answer?   Jul 18 2023, 08:08 AM
StarBear   42 The ultimate answer? Yes, but what’s the ...   Jul 18 2023, 08:35 AM
NARP74   No way to write this without it sounding like a st...   Jul 18 2023, 08:11 AM
TheCabinetmaker   Pm me please. I have what you need, and can walk y...   Jul 18 2023, 10:23 AM
NARP74   Looking for info on this screw. Where the screwdr...   Jul 18 2023, 11:41 AM
partwerks   Looking for info on this screw. Where the screwd...   Aug 12 2023, 10:00 PM
NARP74   I have been told by @TheCabinetmaker that the sp...   Jul 18 2023, 12:40 PM
NARP74   Well, I have a good update and an epic fail update...   Jul 29 2023, 01:24 PM
mepstein   You remove the front bumper and stick a flat blade...   Jul 29 2023, 01:35 PM
NARP74   I think my fiberglass bumper is mounted from the f...   Jul 29 2023, 01:38 PM
mepstein   I think my fiberglass bumper is mounted from the ...   Jul 29 2023, 01:40 PM
NARP74   And I have an oil cooler in that area...   Jul 29 2023, 01:44 PM
TheCabinetmaker   The cable must be screwed in till it stops. The ad...   Jul 29 2023, 02:16 PM
NARP74   Sounds like I have some work ahead of me. I think...   Jul 29 2023, 07:50 PM
NARP74   I think I figured out what might have happened. B...   Jul 30 2023, 09:32 AM
NARP74   I'm in! Necessity is the mother of all sh...   Jul 30 2023, 10:08 AM
TheCabinetmaker   Broken sheath repair. 914 rubber has them, I think...   Jul 30 2023, 10:23 AM
NARP74   That is where I got the idea that the sheath was j...   Jul 30 2023, 10:33 AM
NARP74   MvbQ4wJak_c Channeling Kevin Kline here... So wh...   Aug 12 2023, 08:12 PM
NARP74   Have it, thanks. Specific details are in a post a...   Aug 13 2023, 07:03 AM
Mikey914   [youtube]MvbQ4wJak_c Channeling Kevin Kline her...   Aug 13 2023, 08:59 AM
NARP74   Msg sent, thanks   Aug 13 2023, 10:23 AM
- Lo-Fi Version Time is now: 16th March 2026 - 07:15 PM
