Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Background:
For the stock D-Jet, the ECU gets the signal to fire the injectors from a set of mechanical breaker points inside the base of the distributor. There is nothing wrong with the factory method except for the fact that if you want to run the D-Jet injection, you have to keep the factory distributor...not anymore (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I have successfully been able to electronicly trigger the ECU from a pair of optical sensors inside of the billet Mallory distributor....so far I have only put a few miles onto the car with this setup and I don't know how it'll work when the temperature is much higher (currently it is 45° outside.....) it's ugly right now, but give me some time to clean it up... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/uploads/post-2-1106100569.jpg) So for my ignition, I have the Mallory distributor, accel coil and new 8.5mm plug wires....starts right up and idles fine, but I might install a CDI box anyways... |
KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
Mike,
What timing relationship did you keep between the "ignition points" and the the "trigger" signal?? With your setup can that relationship be varied?? Ken |
Lo-Fi Version | Time is now: 16th June 2024 - 07:03 PM |
