Rear trunk floor replacement |
watsonrx13 |
Sep 26 2007, 06:06 PM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Well, I've done some research on this site, but need some more information. I'm planning to replace the rear trunk floor and noticed McMark's comments on this post.
Here's what McMark suggested for replacing the trunk floor... In this picture I'm assuming that McMark cut the existing floor pan just in front of the center structure, then spot welded the replacement on top, like this? Also, I'm assuming that the sides and the rear section are spot welded to the sides, correct? Finally, my car has the original factory rear sway bars, I'm assuming I need to remove the sway bars, but how do I remove and reinstall the upper piece that is welded to the floor? -- Rob |
McMark |
Sep 28 2007, 12:39 PM
Don't remove good metal just because it's part of the replacement piece. The stamping from Restoration Design is not a recommended fix, it's just a piece of metal that covers a lot of territory. Just cut what you need and don't make more work for yourself by removing the cross member top. (IMG:style_emoticons/default/wink.gif)
930cabman |
Aug 5 2023, 04:24 PM
Advanced Member Group: Members Posts: 3,158 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Don't remove good metal just because it's part of the replacement piece. The stamping from Restoration Design is not a recommended fix, it's just a piece of metal that covers a lot of territory. Just cut what you need and don't make more work for yourself by removing the cross member top. (IMG:style_emoticons/default/wink.gif) Exactly, the RD piece is not needed in many cases. I have found this to be true with many of their pieces. Leaving original sound metal is the the way |
Lo-Fi Version | Time is now: 11th June 2024 - 03:55 AM |
