1.7/1.8 engine case difference? |
Sm914650 |
Aug 5 2023, 07:22 PM
Member Group: Members Posts: 85 Joined: 15-October 18 From: Sf Bay Area Member No.: 22,573 Region Association: Northern California |
Curious if anyone could tell me if there is a difference between 1.8 and 1.7 cases if I were to use a 1.8 case on a 1.7 engine?
wonkipop |
Aug 6 2023, 03:15 AM
Advanced Member Group: Members Posts: 4,367 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
i don't think that is entirely accurate but it may be..
according to PET the 75s start at EC037552. i don't believe they built 12,000 75 1.8s. could be wrong. but pet says 76 1.8s start at 045....(ie which is where 75s end). and as far as i know there were no 76 1.8 (but what you posted implies a handful) and nothing else VW had the engine in 75. so on that basis it ends at approx 45,073 engine units (IMG:style_emoticons/default/confused24.gif) either what you have posted is wrong or the PET is wrong. which still leaves a mystery. a 49K engine number? mis-stamped at the engine factory? or - are you sure it says 49 and you are not misreading 45. wouldn't be the first time someone has come across that sort of mis-stamping/numbering. been detected in VIN sticker recalls for instance. |
Sm914650 |
Aug 6 2023, 06:39 AM
i don't think that is entirely accurate but it may be.. according to PET the 75s start at EC037552. i don't believe they built 12,000 75 1.8s. could be wrong. but pet says 76 1.8s start at 045....(ie which is where 75s end). and as far as i know there were no 76 1.8 (but what you posted implies a handful) and nothing else VW had the engine in 75. so on that basis it ends at approx 45,073 engine units (IMG:style_emoticons/default/confused24.gif) either what you have posted is wrong or the PET is wrong. which still leaves a mystery. a 49K engine number? mis-stamped at the engine factory? or - are you sure it says 49 and you are not misreading 45. wouldn't be the first time someone has come across that sort of mis-stamping/numbering. been detected in VIN sticker recalls for instance. What a trip! Heres a photo of the case in question- looks to definitely be an EC0049 Im stumped! Wonder if it came from a non 914 type 4 case? Hope there is an answer out there somewhere! Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 02:07 AM |
