| Porschef |
Aug 1 2023, 03:45 PM
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States
After all the trials and tribulations by some of the Ljet crew and their struggles with cold starts, it came to me in an early morning haze this morning that maybe I should try bypassing the AAR valve and rigging some sort manual one. I figgered if inadequate air was creating the low idle at start situation, then maybe this would be a way of seeing that an increase in air would remedy that.
Ok, so I pulled the AAR, and set out to get what I needed. Well, here’s where a little laziness took over, I thought before I through that, may I’d see if a total bypass would work… Here’s one of the AAR hoses going from the plenum directly to the intake boot. So being diligent on startup as to not allow a potential crazy high idle, I gave it a shot. Wouldn’t you know, while it was a bit balky to start, when it did the idle shot right up, and I shut it off. Knowing what to expect on the next attempt, it went up to just about 2k rpm, then crept up more. It was enough to convince me that inadequate air is getting into the engine with the stock AAR (which functions perfectly) and that a slightly larger one like VanB has installed will probably be the ticket. Thanks to @Van B @StarBear and @Wonkipop for their quest for perfection (IMG:style_emoticons/default/beerchug.gif) |
| Porschef |
Aug 6 2023, 01:15 PM
Very promising Steve!! (IMG:style_emoticons/default/piratenanner.gif)
Couple things, and I could always be wrong... Your ultimate idle speed shouldn’t be affected, so I’d think that closing down the AAR opening with the nut would be the ticket to bringing down the initial start RPM’s . I understand why you wouldn’t want to as it’s a unit you’ve borrowed. If it’s remaining open just a hair that’d bring the idle up, but also let in unmetered air that you don’t want. Second, I don’t think your AFM would know the difference, it’s kinda like a few components working as one. But yeah, looks really good! (IMG:style_emoticons/default/beerchug.gif) Thanks for all the info (IMG:style_emoticons/default/smile.gif) *Edited* What Van said! |
| StarBear |
Aug 6 2023, 01:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,259 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Very promising Steve!! (IMG:style_emoticons/default/piratenanner.gif) Couple things, and I could always be wrong... Your ultimate idle speed shouldn’t be affected, so I’d think that closing down the AAR opening with the nut would be the ticket to bringing down the initial start RPM’s . I understand why you wouldn’t want to as it’s a unit you’ve borrowed. If it’s remaining open just a hair that’d bring the idle up, but also let in unmetered air that you don’t want. Second, I don’t think your AFM would know the difference, it’s kinda like a few components working as one. But yeah, looks really good! (IMG:style_emoticons/default/beerchug.gif) Thanks for all the info (IMG:style_emoticons/default/smile.gif) *Edited* What Van said! Great ideas. Will order one if third test and drive check out, then do bench tests once it arrives and adjust the nut accordingly. In the home stretch!! |
Porschef A little experiment Aug 1 2023, 03:45 PM
wonkipop @Porschef
nice work.
yeah a straight through ho... Aug 1 2023, 07:24 PM
Van B Ha! Yup, I did the same bypass when I was mes... Aug 1 2023, 09:49 PM
Porschef Thanks Gentlemen, yes, I did go back and read thro... Aug 2 2023, 04:17 AM
wonkipop @Porschef
as a side note porschef, mine star... Aug 2 2023, 06:07 AM
Porschef Awesome, thanks Wonk :beer2:
Mine will do the sa... Aug 2 2023, 06:36 AM
StarBear Sorry for the late response as a bit distracted wi... Aug 2 2023, 06:46 AM
wonkipop
Sorry for the late response as a bit distracted w... Aug 2 2023, 03:52 PM
StarBear Hehehe. Either military intelligence or alien tech... Aug 2 2023, 06:31 PM
wonkipop
Hehehe. Either military intelligence or alien tec... Aug 2 2023, 08:31 PM
Van B
Hehehe. Either military intelligence or alien tec... Aug 2 2023, 10:54 PM
wonkipop
… our stealth tech is little more than funny a... Aug 3 2023, 03:01 AM
Van B
… our stealth tech is little more than funny ... Aug 3 2023, 02:14 PM
wonkipop
[quote name='wonkipop' post='3093282' date='Aug 3... Aug 4 2023, 05:03 AM
ClayPerrine
(ps i just read a story that the b52s are going t... Aug 4 2023, 05:56 AM
wonkipop
(ps i just read a story that the b52s are going ... Aug 5 2023, 12:32 AM
Porschef Great Explanations... :)
Put the AAR back in the... Aug 3 2023, 06:35 AM
StarBear
Ain’t this fun? :bee... Aug 3 2023, 06:57 AM
wonkipop
Put the AAR back in th... Aug 3 2023, 05:47 PM
Van B @Porschef
I posted pictures of the two in my ori... Aug 3 2023, 01:11 PM
Porschef Ok, fellow Ljet brethrens,
@Van B
[b]@[url=ht... Aug 4 2023, 08:18 AM
Van B @Porschef my original tested good. It heated up,... Aug 4 2023, 08:37 AM
Porschef
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 4 2023, 09:24 AM
Van B BTW, your AFRs are perfect! Aug 4 2023, 08:39 AM
Porschef
Thanks, it doe... Aug 4 2023, 08:57 AM
StarBear Thanks for the summary @porschef .
Based on your... Aug 4 2023, 02:12 PM
Porschef
Thanks for the summary [b]@[url=http://www.914wo... Aug 4 2023, 03:14 PM
Geezer914 Rock Auto 1988 BMW M5 idle air control valve ... Aug 5 2023, 06:39 AM
Porschef
Rock Auto 1988 BMW M5 idle air control valve ... Aug 5 2023, 07:32 AM
Geezer914 I second that. Aug 5 2023, 11:36 AM
wonkipop down here in north antarctica we have this bloke h... Aug 5 2023, 03:35 PM
Porschef Very interesting Wonk, that’s the site I used to... Aug 5 2023, 04:15 PM
wonkipop
Very interesting Wonk, that’s the site I used t... Aug 6 2023, 02:52 AM
StarBear Here are the results of the AAR temp tests - OEM B... Aug 6 2023, 10:23 AM
StarBear Results of current AAR (Bosch/VW #101) unit testin... Aug 6 2023, 10:39 AM
Porschef A little Sunday afternoon suspense...that’s pret... Aug 6 2023, 12:27 PM
StarBear Ok; second test, with bigger BMW AAR. What a diffe... Aug 6 2023, 01:01 PM
Van B @StarBear , you gotta set the TB air screw when th... Aug 6 2023, 01:10 PM
StarBear
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 6 2023, 01:19 PM
StarBear Ok, Test 3. New Bosch /BMW larger AAR with initial... Aug 6 2023, 02:18 PM
Van B In the winter it will obviously stay at the 1200-1... Aug 6 2023, 02:24 PM
Porschef Awesome Steve! :) Thanks to you and Van for t... Aug 6 2023, 02:27 PM
Geezer914 Thanks for sharing all your research and testing... Aug 6 2023, 04:16 PM
wonkipop nice work @StarBear .
inspired me.
soon as its ... Aug 6 2023, 06:22 PM
Porschef Ordered the BMW AAR from Rock Auto last Tuesday an... Aug 13 2023, 01:34 PM
wonkipop
Ordered the BMW AAR from Rock Auto last Tuesday a... Aug 14 2023, 03:12 AM
StarBear Mine arrived Saturday, also from Roch Auto. Some t... Aug 14 2023, 05:49 AM
wonkipop
Mine arrived Saturday, also from Roch Auto. Some ... Aug 14 2023, 04:56 PM
Porschef Congratulations Steve
Car looks fantastic! :b... Aug 14 2023, 06:26 AM
Van B Well that's pretty cool! I bet it was the ... Aug 14 2023, 06:40 AM
StarBear
Well that's pretty cool! I bet it was the... Aug 14 2023, 08:26 AM
Van B You really need that nice and toasty engine for se... Aug 14 2023, 08:40 AM
Porschef
You really need that nice and toasty engine for s... Aug 14 2023, 09:07 AM
StarBear
You really need that nice and toasty engine for s... Aug 14 2023, 05:04 PM
StarBear @porschef
Did new AAR bench tests today. To get f... Aug 14 2023, 03:25 PM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 14 2023, 05:02 PM
Van B I’m noticing a trend here… @StarBear likes t... Aug 14 2023, 05:04 PM
StarBear
I’m noticing a trend here… [b]@[url=http://w... Aug 14 2023, 05:07 PM
Van B
Also, both the AAV and the idle bypass screw are... Aug 15 2023, 06:20 AM
Porschef
You're killing me Steve. All air is metered ... Aug 15 2023, 06:26 AM
wonkipop
Also, both the AAV and the idle bypass screw ar... Aug 15 2023, 07:07 AM
Van B Slightly rich, but definitely in the window! Aug 14 2023, 05:07 PM
Geezer914 more like 13.6 cruising and 12.5 on acceleration. ... Aug 14 2023, 05:40 PM
StarBear Did oven test to 140-150F. Still didn’t close al... Aug 14 2023, 07:17 PM
Van B Well, that amount it was still open is definitely ... Aug 14 2023, 07:55 PM
Porschef Between Saturday night and the present moment weâ€... Aug 15 2023, 01:31 AM
wonkipop
we are mere humans @[url=http://www.914world.co... Aug 15 2023, 04:25 AM
Porschef
we are mere humans
perfection is best left to... Aug 15 2023, 05:21 AM
StarBear Dig through my files and found a short write up fr... Aug 15 2023, 05:43 AM
wonkipop
Dig through my files and found a short write up f... Aug 15 2023, 07:04 AM
StarBear A final (?) question: ok, if I accept a bit remain... Aug 15 2023, 06:07 AM
Porschef
A final (?) question: ok, if I accept a bit remai... Aug 15 2023, 06:21 AM
StarBear
A final (?) question: ok, if I accept a bit rema... Aug 15 2023, 07:31 AM
wonkipop
[quote name='Porschef' post='3095746' date='Aug 1... Aug 16 2023, 03:23 AM
Porschef Yeah I did a fair amount of fiddlin’ with it, Iâ... Aug 15 2023, 06:14 AM
Van B Then you should enjoy it! Aug 15 2023, 06:31 AM
Porschef
Hah, it’s all g... Aug 15 2023, 06:45 AM
wonkipop
Hah, it’s all ... Aug 15 2023, 07:05 AM
StarBear Hah!
It IS the 21st century and we still donâ... Aug 16 2023, 11:00 AM
Van B Bathroom... They are generally a shitty place to b... Aug 16 2023, 07:17 PM
wonkipop @Van B and [b]@[url=http://www.914world.com/bbs2... Aug 18 2023, 03:37 AM
StarBear Done! Trial testing completed!
The 914 rep... Aug 18 2023, 11:03 AM
euro911 I've cleaned up old clogged AARs before. As lo... Aug 18 2023, 11:20 AM
Van B That’s better that most pros steveo! Aug 18 2023, 12:12 PM
Porschef
Doe... Aug 18 2023, 01:47 PM
StarBear
Do... Aug 18 2023, 02:33 PM
StarBear
And a... Aug 18 2023, 02:34 PM
Geezer914 Porschef, is that with the AC358 AAR valve? What ... Aug 18 2023, 03:54 PM
Porschef Yes. Running it straight out of the box made for t... Aug 18 2023, 07:02 PM
StarBear Ok, new larger AC358 (BMW) Bosch 125 AAR installed... Aug 19 2023, 03:58 PM
Van B How old is your VR? Aug 19 2023, 04:01 PM
StarBear
How old is your VR?
You mean the vacuum can? May... Aug 19 2023, 05:30 PM
wonkipop
How old is your VR?
:) yeah whats the VR?
you... Aug 19 2023, 05:55 PM
StarBear Oh, voltage regulator? A few years old. Nothing o... Aug 19 2023, 05:59 PM
Van B
Oh, voltage regulator? A few years old. Nothing ... Aug 19 2023, 06:02 PM
Van B Voltage regulator. I’m sure you all call it Bru... Aug 19 2023, 06:00 PM
StarBear
Voltage regulator. I’m sure you all call it Br... Aug 19 2023, 06:03 PM
wonkipop
Voltage regulator. I’m sure you all call it Br... Aug 19 2023, 06:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:22 AM |
