| R Dub |
Aug 6 2023, 12:52 PM
Member ![]() ![]() Group: Members Posts: 126 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
Was driving the 914 to work the other day and half way there I couldn't get 4th and barley was able to get 5th. After inspection the side coupler bushing broke. I can get the plastic or rubber ones from 914Rubber for pretty cheap but I saw Pelican Parts has these brass ones. Are the brass ones worth the additional cost? Anyone have any experience with them?
| Mikey914 |
Aug 7 2023, 09:39 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
The brass are nice in theory. Rememer the originals lasted decades, so yes we are seeing more that need to be replaced, but either one you put in is likely to be the last time you have to mess with it.
The nylon has some give to it, this facilitates an easier install and some accomidation of variances from temperature change and wear. The brass will simply take up some of the ability to have flexability. Think of it as analog vs digital. You can have a high degree of accuracy woth analog ...say 99.5%, the digital is 100%, but it has less margin for adjustment and compensation of variations in temperature. So yoy can choose either, but they bith havevpros and cons. It is my opinion that the OEM style offer the best bang for the buck, but to each thier own. |
| 930cabman |
Aug 7 2023, 09:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
The brass are nice in theory. Rememer the originals lasted decades, so yes we are seeing more that need to be replaced, but either one you put in is likely to be the last time you have to mess with it. The nylon has some give to it, this facilitates an easier install and some accomidation of variances from temperature change and wear. The brass will simply take up some of the ability to have flexability. Think of it as analog vs digital. You can have a high degree of accuracy woth analog ...say 99.5%, the digital is 100%, but it has less margin for adjustment and compensation of variations in temperature. So yoy can choose either, but they bith havevpros and cons. It is my opinion that the OEM style offer the best bang for the buck, but to each thier own. Agreed and disagreed Brass is too rigid, a bit of give is good here Yes the originals lasted for decades, but new factory originals are too sloppy for my liking. New Delrin with tighter tolerances works well for me. |
R Dub Side shift coupler bushing Aug 6 2023, 12:52 PM
mate914
Was driving the 914 to work the other day and hal... Aug 6 2023, 01:00 PM
Morrie
Was driving the 914 to work the other day and hal... Aug 6 2023, 03:36 PM
porschetub
Was driving the 914 to work the other day and hal... Aug 6 2023, 03:53 PM
R Dub I decided to pull the pin on the brass ones. My me... Aug 6 2023, 08:33 PM
930cabman I had my friendly local machinist make new bushing... Aug 7 2023, 04:58 AM
914Sixer I have the brass one. Plan on doing some work on ... Aug 7 2023, 06:02 AM
technicalninja If the brass bushing is "sintered" there... Aug 7 2023, 06:19 AM
Bartlett 914
If the brass bushing is "sintered" ther... Aug 7 2023, 04:55 PM
DRPHIL914
I decided to pull the pin on the brass ones. My m... Aug 7 2023, 07:03 AM
dr914@autoatlanta.com no brass wears things out, get the delrin perfect ... Aug 7 2023, 08:25 AM
dr914@autoatlanta.com the after market delrin are the way to go, perfect... Aug 7 2023, 10:03 AM
Olympic 914 Anyone have a link to the Delrin bushings? For th... Aug 7 2023, 10:12 AM
ClayPerrine You can always replace the coupler with the steeri... Aug 7 2023, 11:20 AM
930cabman
You can always replace the coupler with the steer... Aug 7 2023, 11:42 AM
ClayPerrine
[quote name='ClayPerrine' post='3094204' date='Au... Aug 7 2023, 02:04 PM
Porschef Agree with the delrin bushing, I spun one up on th... Aug 7 2023, 12:00 PM
ClayPerrine Found a picture of the shift coupler on my six con... Aug 7 2023, 02:08 PM
second wind Very interesting post....we all want "Toyota... Aug 7 2023, 05:27 PM
second wind
Very interesting post....we all want "Toyota... Aug 7 2023, 05:32 PM
second wind OK....it is a Tangerine Racing part....sorry about... Aug 7 2023, 06:47 PM
ChrisFoley :chair: :wavebye: Aug 8 2023, 04:06 AM
DRPHIL914
OK....it is a Tangerine Racing part....sorry abou... Aug 8 2023, 05:22 AM
Porschef Yes, it’s Chris’ creation. Very easy to instal... Aug 8 2023, 05:36 AM
R Dub Ok folks, kinda stuck. The brass bushings came in.... Aug 11 2023, 07:34 PM
rfinegan JWest makes urethane coupler bushing for about 15 ... Aug 12 2023, 07:20 AM
R Dub Ok just got it figured out. Had the wife sit in th... Aug 12 2023, 11:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:35 PM |
