> Noise insulation, Engineer types opinions needed
nivekdodge
post Aug 10 2023, 07:12 PM
Just a thought
There's another thread today discussing using perlon for the back pad and if it was quieter or not. Something I've notice is Some GM hood have their inner surface looking like a golf ball. There are 3" round divots and when asked about it I was told it reflects the sound back to the motor and that kills the sound.Anyone know if there is truth to this?
This would of course be in the engine compartment.
Kevin
vitamin914
post Aug 11 2023, 03:25 PM
This got me curious... Head impact protection on the hood is what it is.
Found a 2008 GM research paper at the NHTSA...
ABSTRACT
Besides functioning as an engine compartment cover, the hood of modern vehicles can also help manage the impact energy of a pedestrian’s head in a vehicle-pedestrian impact. However, a hood’s ability to absorb impact energy may be impeded by the proximity of the hood to components packaged inside the engine compartment, i.e., by its underhood clearance. For example, for a given hood design, the hood’s ability to absorb impact energy through deformation can be significantly reduced when the hood and engine block are in close proximity. Therefore, a large underhood clearance would be preferred for pedestrian protection. However, it could negatively affect driver visibility, as well as a vehicle’s aerodynamics and aesthetic appeal. This paper presents a sandwich hood design that has a potential to improve the hood’s ability to absorb the impact energy of a pedestrian’s head with a relatively small underhood clearance.
Final conclusion was a corrugated under hood works, but is 27% heavier than the standard hood and was not evaluated for manufacturability. Guess they figured it out and put it into production. But like Superhawk said, designed for regulations to the detriment of the vehicle and does nothing for the driver or driving experience.
Found references to a Mercedes patent for putting in pedestrian hood airbags. Today our 914s would weigh 3000+lbs with this thinking. Isn't that what the 718 weighs?
nivekdodge   Noise insulation   Aug 10 2023, 07:12 PM
mepstein   Perlon is a very lightweight material. You will ha...   Aug 11 2023, 06:11 AM
vitamin914   Just a thought There's another thread today ...   Aug 11 2023, 07:15 AM
Superhawk996   … designed to reduce head impact forces in a co...   Aug 11 2023, 10:42 AM
Alain V.   … designed to reduce head impact forces in a c...   Aug 11 2023, 04:46 PM
wonkipop   … designed to reduce head impact forces in a c...   Aug 12 2023, 07:09 AM
nivekdodge   Like I said, I had heard this in passing and was c...   Aug 11 2023, 07:44 AM
914_teener   Yes there is truth to it. Sound is energy and it...   Aug 11 2023, 10:02 AM
vitamin914   This got me curious... Head impact protection on t...   Aug 11 2023, 03:25 PM
Rusty   Not sure how much value this will add, but here go...   Aug 12 2023, 08:09 AM
Superhawk996   Not sure how much value this will add, but here g...   Aug 12 2023, 10:59 AM
Mikey914   Just a thought There's another thread today ...   Aug 12 2023, 08:26 AM
vitamin914   The only way to "kill" noise is to 1- ...   Aug 12 2023, 01:32 PM
bahnzai   Just a thought There's another thread today...   Aug 12 2023, 07:06 PM
Mikey914   I haven't yet, but was going to play with this...   Aug 13 2023, 08:53 AM
r_towle   You can attack the firewall problem but in the end...   Aug 13 2023, 09:37 AM
Bucci   You can attack the firewall problem but in the en...   Aug 13 2023, 10:17 AM
Superhawk996   [quote name='r_towle' post='3095382' date='Aug 13...   Aug 13 2023, 10:29 AM
vitamin914   [quote name='r_towle' post='3095382' date='Aug 1...   Aug 13 2023, 11:06 AM
Bucci   [quote name='r_towle' post='3095382' date='Aug 1...   Aug 13 2023, 11:36 PM
Geezer914   I used Perlon on the panel behind the seats and Dy...   Aug 13 2023, 09:41 AM
Rob-O   You can attack the firewall problem but in the en...   Aug 13 2023, 09:44 AM
Root_Werks   I had a 914 rear window cut from laminated glass o...   Aug 14 2023, 10:23 AM
- Lo-Fi Version Time is now: 4th June 2026 - 01:08 PM
