Deck height, compression ratio, and valve relief flat top pistons, In a 2.0 |
emerygt350 |
Jul 13 2023, 11:41 AM
Advanced Member Group: Members Posts: 2,144 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Ok, my question of the day:
Put my new 96mm pistons and cylinders on and measured deck height, .033 all the way around. Let's say .032 to be conservative. I will not be running head gaskets. The calculator gives me 8.8 CR at .033 8.6 CR at .043 8.4 CR at .053 The pistons have a valve relief (pretty large) cut. I am shooting for 8.4 CR. Heads are in the shop so I can't check the CC yet. Everything I read says .04 - .06 for deck height. With the valve relief do I need to worry about going lower? If I had dishes would you measure from the edge of the piston or the dish? |
emerygt350 |
Aug 11 2023, 03:33 PM
Lo-Fi Version | Time is now: 7th June 2024 - 09:10 PM |
