Timing marks |
Timing marks |
aeginc77 |
Aug 11 2023, 04:37 PM
Newbie Group: Members Posts: 19 Joined: 29-April 15 From: United States Member No.: 18,682 Region Association: None |
I recently installed an electronic ignition replacing the point and condensoer. Now I want to check the timing but I can't find any timing marks on the fan! I see the notch in the housing but even when I align the rotor to the #1 lead and look at the fan I cannot see any timing marks not the TDC mark never mind the 27.5 before TDC. Has anyone run across this and what is the solution?
Thanks |
914sgofast2 |
Aug 12 2023, 12:22 PM
Senior Member Group: Members Posts: 622 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I think the Pelican Parts website has an article about timing marks in its technical subsection. The early cars had three (3) timing marks for TDC, 8 degrees static, and full advance at 2800rpm with vacuum hoses disconnected and plugged. Some engines only had one timing mark; I have a cooling fan from a 1.8 liter like that.
aeginc77 |
Aug 12 2023, 12:55 PM
I think the Pelican Parts website has an article about timing marks in its technical subsection. The early cars had three (3) timing marks for TDC, 8 degrees static, and full advance at 2800rpm with vacuum hoses disconnected and plugged. Some engines only had one timing mark; I have a cooling fan from a 1.8 liter like that. I have seen pictures of the marks....I have several - all wrong. lol. I say this because when the rotor is pointing at or near the #1 lead there are no timing marks showing or even close! The car actually drives well but I really wanted to actually see how it was timed. Pelican does have a good article about finding TDC by looking at top of transmission with a mirror. I think I'll leave it to my local shop to find and mark the actual timing marks.....with indelible paint! |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:57 AM |
