Timing marks |
Timing marks |
aeginc77 |
Aug 11 2023, 04:37 PM
Newbie Group: Members Posts: 19 Joined: 29-April 15 From: United States Member No.: 18,682 Region Association: None |
I recently installed an electronic ignition replacing the point and condensoer. Now I want to check the timing but I can't find any timing marks on the fan! I see the notch in the housing but even when I align the rotor to the #1 lead and look at the fan I cannot see any timing marks not the TDC mark never mind the 27.5 before TDC. Has anyone run across this and what is the solution?
Thanks |
Jack Standz |
Aug 12 2023, 02:13 PM
Member Group: Members Posts: 279 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
Good point, sometimes you can catch a view of the timing mark(s) with a mirror from the other side of the fan housing. Also, some flywheels may have TDC marked too but this may require pulling the rear engine tin slightly out of position or viewing from below the car. Actually, some people prefer marking the flywheel & will mark TDC and 180 degrees out for such things as valve adjustment procedures (can tell where the camshaft is supposedto be without crawling out from under the car. Thanks for the suggestions but my 914 looks like it has a cast aluminum fan casing. There is no tin work to remove at least while the engine is in the car! There are two very clear timing marks both way off so far off that if I line up the TDC mark with the v notch the rotor point halfway between leads to cylinders 3 and 4! I think I am faced with gettin gunder the car with mirror and searching for mark on top of transmission which from the descriptions I have read seems like a virtually impossible task! There is a tin piece at the rear top of the motor that you can push just enough (without removing) to see the flywheel. See attached photo. It's at the "12 o'clock position of the flywheel". Much easier than trying from under the car with a mirror. Never mind, just stick with marking the fan. Also, your distributor drive may be installed incorrectly. So, the suggestion is to find and mark TDC on #1 compression stroke, then use a dial back timing light. Attached image(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:10 AM |
