> Need a pep talk/help: can't eliminate exhaust leak after 5 attempts
DC_neun_vierzehn
post Aug 12 2023, 07:41 PM
Looking for some advice and encouragement because I'm ready to say "uncle."
I have a '73 2.0 w/ a fresh 2056 rebuild. Exhaust studs are new. I have new exhaust stud nuts from @rhodyguy . I have new Victor Reinz copper washers and exhaust gaskets. My heat exchangers (HEs) are stock (not stainless).
By using the shop vac blow up the tailpipe method, I have detected exhaust leaks on the passenger side (PS) at both exhaust ports as well as at the muffler gasket.
Here's the method I used on the driver's side (DS) and it worked perfectly: a dab of Elmer's glue on the copper washers to get them to sit in the heads and used the X pattern to tighten the nuts moving to the next nut after 3 rotations. Worked perfectly, no air leaks.
I tried the same method on the PS HE, but it failed to eliminate the air leaks at the head after 5 straight attempts of removing and reinstalling. SO FRUSTRATING.
Based off of past threads I found via the search, the only things left to try:
1. Gently file the HE pipes to square them off (use a Sharpie to mark the tops and only file until ink is gone using a large bastard file that will do both pipes simultaneously). I did not do this yet because the pipe ends look flat and clean. When I set one of the copper washers on the top of the pipes they sit flat and even - when I shine a flashlight behind that I don't see any light coming through.
2. Anneal the copper gaskets using a blowtorch - I have no idea how I would get the copper gaskets to sit in the heads after annealing them and then lay on my back underneath them while trying to install the HE sounds a burn victim waiting to happen. How does one do this safely?
I'll take any suggestions or encouragement because after spending 4-5 hours on this today, I'm feeling a bit hopeless.
post Aug 12 2023, 08:09 PM
914-6 GT in waiting
When you anneal them, you get them red hot and then let them cool completely before you install.
I like using superglue to hold gaskets in the heads when you’re working upside down.
To check the flatness of the ends, you need to have something that’s known to be flat, like a piece of glass, granite table, machinist block, ect.
Good luck. (IMG:style_emoticons/default/beerchug.gif)
DC_neun_vierzehn   Need a pep talk/help: can't eliminate exhaust leak after 5 attempts   Aug 12 2023, 07:41 PM
mepstein   When you anneal them, you get them red hot and the...   Aug 12 2023, 08:09 PM
BeatNavy   Mark is right. The only other thoughts I have: 1...   Aug 12 2023, 08:27 PM
rhodyguy   File the ends. You might see a miss spot on the fi...   Aug 12 2023, 08:30 PM
DC_neun_vierzehn   Silly question. Positive both old copper rings re...   Aug 13 2023, 07:00 AM
914_teener   I went through this same issue but with the SSHE...   Aug 12 2023, 10:03 PM
930cabman   I said uncle. My recent 2056 build with SS exchan...   Aug 13 2023, 04:48 AM
barefoot   I have the SSI's and filed the seal surfaces w...   Aug 13 2023, 05:34 AM
Porschef   Yes, retorque after a run. A little gentle up and ...   Aug 13 2023, 06:44 AM
DC_neun_vierzehn   Thanks everyone for the encouragement/suggestions ...   Aug 13 2023, 06:59 AM
bkrantz   The exchanger pipe ends need to be not just flat b...   Aug 13 2023, 07:30 PM
ClayPerrine   I will add my experience here. Loose assemble eve...   Aug 14 2023, 08:16 AM
DC_neun_vierzehn   I will add my experience here. Loose assemble ev...   Aug 14 2023, 10:26 AM
DC_neun_vierzehn   I will add my experience here. Loose assemble e...   Aug 14 2023, 01:29 PM
r_towle   I will add my experience here. Loose assemble ev...   Aug 15 2023, 05:46 PM
76-914   I use a different method to dress the header. As M...   Aug 14 2023, 08:48 AM
ClayPerrine   Standard torque specification for a 8x1.25 bolt is...   Aug 14 2023, 02:31 PM
rjames   I'm paranoid about overtightening the exhaust ...   Aug 14 2023, 03:40 PM
mgphoto   The number I look for here is 122 inch pounds, the...   Aug 15 2023, 03:37 PM
iankarr   Permatex 81878 max temp gasket maker is your frien...   Aug 15 2023, 04:20 PM
DC_neun_vierzehn   Thanks everyone. The careful/light filing of the...   Aug 16 2023, 09:10 PM
Eric_Ciampa   I just wrapped up installation of headers. Same ad...   Aug 16 2023, 09:48 PM
IronHillRestorations   Before you torque the nuts at the heads, use a fla...   Aug 24 2023, 04:09 PM
nathanxnathan   I have always quenched the gaskets in water after ...   Aug 24 2023, 05:20 PM
- Lo-Fi Version Time is now: 18th September 2025 - 05:22 PM
