DC_neun_vierzehn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 568 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region ![]() ![]() |
Looking for some advice and encouragement because I'm ready to say "uncle."
I have a '73 2.0 w/ a fresh 2056 rebuild. Exhaust studs are new. I have new exhaust stud nuts from @rhodyguy . I have new Victor Reinz copper washers and exhaust gaskets. My heat exchangers (HEs) are stock (not stainless). By using the shop vac blow up the tailpipe method, I have detected exhaust leaks on the passenger side (PS) at both exhaust ports as well as at the muffler gasket. Here's the method I used on the driver's side (DS) and it worked perfectly: a dab of Elmer's glue on the copper washers to get them to sit in the heads and used the X pattern to tighten the nuts moving to the next nut after 3 rotations. Worked perfectly, no air leaks. I tried the same method on the PS HE, but it failed to eliminate the air leaks at the head after 5 straight attempts of removing and reinstalling. SO FRUSTRATING. Based off of past threads I found via the search, the only things left to try: 1. Gently file the HE pipes to square them off (use a Sharpie to mark the tops and only file until ink is gone using a large bastard file that will do both pipes simultaneously). I did not do this yet because the pipe ends look flat and clean. When I set one of the copper washers on the top of the pipes they sit flat and even - when I shine a flashlight behind that I don't see any light coming through. 2. Anneal the copper gaskets using a blowtorch - I have no idea how I would get the copper gaskets to sit in the heads after annealing them and then lay on my back underneath them while trying to install the HE sounds a burn victim waiting to happen. How does one do this safely? I'll take any suggestions or encouragement because after spending 4-5 hours on this today, I'm feeling a bit hopeless. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,865 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Before you torque the nuts at the heads, use a flashlight and make sure the exhaust pipes are centered on the copper gaskets. You probably can’t get all four to be perfectly centered, but make sure a pipe isn’t off the copper.
Lo-Fi Version | Time is now: 18th September 2025 - 05:22 PM |
