| Bigdamdork |
Aug 24 2023, 05:31 PM
Newbie ![]() Group: Members Posts: 22 Joined: 19-July 23 From: Santa Maria, CA Member No.: 27,476 Region Association: Central California |
Hey Everyone. Based in no small part on the suggestions from my original thread about what order to do my restore I picked up some steel and pushed my Makita metal cut-off saw the limit. I'm ready to start putting this together. My question is I have a Weldpack 3200. I bought it a couple of years ago just to play with things. Some metal art, built a Santa Maria Style BBQ, etc. Per the instructions, the metal is .125 (so close to 11 gauge?) for the 2x4's. Am I fooling myself by thinking I could use this welder to put the jig together? The welder says it can handle 12ga to 1/4" with .035 gasless flux cored wire DC(-). I just don't know enough about the duty cycle, etc. to know if I should just suck it up and buy a bigger welder. I figure once I get into the car I should be fine as it's mostly 18ga sheet metal so I hate to buy one just for the jig but will if I need to I guess. Maybe find a buddy with one. Just wanted to get some expert's thoughts as my total welding time is about 2 hours. I plan on being an expert post-rebuild. (IMG:style_emoticons/default/unsure.gif)
Super appreciate any advice you can offer. Thank You!! ![]() ![]() [attachmentid=885729] ![]() Attached image(s)
| flat4guy |
Aug 24 2023, 08:45 PM
Member ![]() ![]() Group: Members Posts: 477 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California |
I have helped a friend build 3 cars using this same welder - we did floors, quarters and more. Good welder.
Bigdamdork Welding Question Aug 24 2023, 05:31 PM
jhynesrockmtn Try it or test on a similar gauge metal. If the w... Aug 24 2023, 06:49 PM
Superhawk996 It will work
I just used a whimpy 120v welder to... Aug 24 2023, 08:40 PM
targa72e I think the important part is you are not making a... Aug 24 2023, 09:50 PM
MikeK With that 110V welder, I’d consider tapering the... Aug 25 2023, 01:42 AM
mb911 Ok I hate these threads only because 99.9% of the ... Aug 25 2023, 05:47 AM
Superhawk996 @mb911
Curious about the duty cycle. His machi... Aug 25 2023, 06:43 AM
mb911
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 25 2023, 07:19 AM
76-914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 25 2023, 06:22 PM
Shivers
I’m using the same welder. I built this contr... Aug 25 2023, 06:58 AM
mlindner And then if you are using an extension cord, keep ... Aug 25 2023, 08:53 AM
Superhawk996
And then if you are using an extension cord, keep... Aug 25 2023, 11:42 AM
930cabman Try it and keep your eye on overheating the machin... Aug 25 2023, 09:11 AM
Jack Standz Not an expert here, but you'll probably be hap... Aug 25 2023, 11:42 AM
mb911 Ok one last tidbit. So there is this negative thou... Aug 25 2023, 04:31 PM
Superhawk996
. . .(they make a gas shield version).
Do tel... Aug 25 2023, 11:33 PM
mb911
[quote name='mb911' post='3098005' date='Aug 25 2... Aug 26 2023, 05:29 AM
Superhawk996
[quote name='mb911' post='3098005' date='Aug 25 ... Aug 26 2023, 06:55 AM
Jack Standz Yes, choose the right process for the project and ... Aug 25 2023, 04:47 PM
willieg A welder, working on an exterior staircase, told m... Aug 26 2023, 08:30 AM
mb911
A welder, working on an exterior staircase, told ... Aug 26 2023, 09:42 AM
Front yard mechanic Hard to beat an old school stick welder for tube a... Aug 26 2023, 09:57 AM
targa72e I think this topic diverged a lot. There is a ton ... Aug 26 2023, 10:43 PM
MikeK
I think this topic diverged a lot. There is a ton... Aug 27 2023, 08:24 AM
Shivers https://www.nexair.com/learning-center/you-...of%2... Aug 27 2023, 09:17 AM
Bigdamdork Just wanted to say "THANK YOU" for the i... Aug 30 2023, 03:33 PM
Superhawk996 Speaking only for myself - I’m no expert. I get... Aug 30 2023, 04:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:22 PM |
