> Welding Question, Welding
Bigdamdork
post Aug 24 2023, 05:31 PM
Hey Everyone. Based in no small part on the suggestions from my original thread about what order to do my restore I picked up some steel and pushed my Makita metal cut-off saw the limit. I'm ready to start putting this together. My question is I have a Weldpack 3200. I bought it a couple of years ago just to play with things. Some metal art, built a Santa Maria Style BBQ, etc. Per the instructions, the metal is .125 (so close to 11 gauge?) for the 2x4's. Am I fooling myself by thinking I could use this welder to put the jig together? The welder says it can handle 12ga to 1/4" with .035 gasless flux cored wire DC(-). I just don't know enough about the duty cycle, etc. to know if I should just suck it up and buy a bigger welder. I figure once I get into the car I should be fine as it's mostly 18ga sheet metal so I hate to buy one just for the jig but will if I need to I guess. Maybe find a buddy with one. Just wanted to get some expert's thoughts as my total welding time is about 2 hours. I plan on being an expert post-rebuild. (IMG:style_emoticons/default/unsure.gif)
Super appreciate any advice you can offer. Thank You!!
Attached Image Attached ImageAttached ImageAttached Image[attachmentid=885
729]Attached Image
Superhawk996
post Aug 25 2023, 06:43 AM
@mb911
Curious about the duty cycle. His machine like mine is a very low duty cycle.
In my case; welding thicker material than I should. As bead goes down, it does a good job of heating that thick base metal. This makes me want to keep running bead. But I feel compelled to only weld for about 2 minutes and then let the machine cool before doing the next bead. The problem is allowing the machine to cool also allows the thick base to cool which I really don’t want.
Any thoughts on how to best handle the low duty cycle? What fails if overheated - I assume rectification diodes?
mb911
post Aug 25 2023, 07:19 AM
QUOTE(Superhawk996 @ Aug 25 2023, 04:43 AM) *
@mb911
20% duty cycle is 2 minutes of straight welding. That’s a lot of welding. Most people complete a weld in 10-30 seconds. If running max amperage that 2 minutes of max amperage is quite a weld. Most amateur welders never are going to be doing welds to exceed duty cycles. Also remember when exceeded amperage occurs most machines will not provide output until the machine has cooled.
Bigdamdork   Welding Question   Aug 24 2023, 05:31 PM
jhynesrockmtn   Try it or test on a similar gauge metal. If the w...   Aug 24 2023, 06:49 PM
Superhawk996   It will work I just used a whimpy 120v welder to...   Aug 24 2023, 08:40 PM
flat4guy   I have helped a friend build 3 cars using this sam...   Aug 24 2023, 08:45 PM
targa72e   I think the important part is you are not making a...   Aug 24 2023, 09:50 PM
MikeK   With that 110V welder, I’d consider tapering the...   Aug 25 2023, 01:42 AM
mb911   Ok I hate these threads only because 99.9% of the ...   Aug 25 2023, 05:47 AM
Superhawk996   @mb911 Curious about the duty cycle. His machi...   Aug 25 2023, 06:43 AM
mb911   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 25 2023, 07:19 AM
76-914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 25 2023, 06:22 PM
Shivers   I’m using the same welder. I built this contr...   Aug 25 2023, 06:58 AM
mlindner   And then if you are using an extension cord, keep ...   Aug 25 2023, 08:53 AM
Superhawk996   And then if you are using an extension cord, keep...   Aug 25 2023, 11:42 AM
930cabman   Try it and keep your eye on overheating the machin...   Aug 25 2023, 09:11 AM
Jack Standz   Not an expert here, but you'll probably be hap...   Aug 25 2023, 11:42 AM
mb911   Ok one last tidbit. So there is this negative thou...   Aug 25 2023, 04:31 PM
Superhawk996   . . .(they make a gas shield version). Do tel...   Aug 25 2023, 11:33 PM
mb911   [quote name='mb911' post='3098005' date='Aug 25 2...   Aug 26 2023, 05:29 AM
Superhawk996   [quote name='mb911' post='3098005' date='Aug 25 ...   Aug 26 2023, 06:55 AM
Jack Standz   Yes, choose the right process for the project and ...   Aug 25 2023, 04:47 PM
willieg   A welder, working on an exterior staircase, told m...   Aug 26 2023, 08:30 AM
mb911   A welder, working on an exterior staircase, told ...   Aug 26 2023, 09:42 AM
Front yard mechanic   Hard to beat an old school stick welder for tube a...   Aug 26 2023, 09:57 AM
targa72e   I think this topic diverged a lot. There is a ton ...   Aug 26 2023, 10:43 PM
MikeK   I think this topic diverged a lot. There is a ton...   Aug 27 2023, 08:24 AM
Shivers   https://www.nexair.com/learning-center/you-...of%2...   Aug 27 2023, 09:17 AM
Bigdamdork   Just wanted to say "THANK YOU" for the i...   Aug 30 2023, 03:33 PM
Superhawk996   Speaking only for myself - I’m no expert. I get...   Aug 30 2023, 04:08 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:21 PM
